hey,
am undecided on whether to go for bosch 040, or just buy a stock r33 pump.
My mods are aswell follows for the rb25det motor.
custom inlet plenum (front facing)
new dump pipi with seperate waste gate pipe re joined this time
front mount intercooler
rampod
hks hi power exhaust from cat back
hi flow cat 3 inch
front pipe 3 inch
maybe 12psi boost on high setting. (stock turbo though so..)
5 puk brass button clutch
am running ngk iridium plugs.
I'd imagine this would make somewhere around the 180rwkw mark at most, going off what other guys are doing.
is the stock fuel pump ok for this. i dont know as i never had a skyline before. WHat are the stock r33 ones rated at. if anyone could let me know would be great. either if i can go the r33 stock pump, or maybe just go for something a little bigger.
its for the intank silvia fuel set up.
cheers
Guest INASNT
Originally posted by dabigbolf
hey,
rampod
hi flow cat 3 inch
front pipe 3 inch
cheers
yep u will be right with 180odd rwkw.
aint u putting a new turbo on?
yeah will be putting a new turbo on, but for now its not worth me getting the big fuel pump.
i will not be upgrading for a while.
plus need to get cooler piping done, and tailshaft shortened, so could do with the money spent there.
anyone got a stock r33 turbo fuel pump located in melb.
cheers
cheers
Soon, once i upgrade my fuel system for the turbo.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
