Trying to get an idea how much i should expect for my 32 as I wish to move to 34 shortly. The car isn't finished to what I want, though thats why im deciding on things now.
Its currently in the shops as a taxi cut me off and scratched up the drivers side. Not really much body damage, more paint than anything. The entire car is being sprayed (hasn't begun as of yet), so this might be a good chance to get what u want as its covered by his insurance :D
1992 gtst, silver
2nd owner since being brought over.
All round pretty high condition.
Sunroof
100k on dash
Serviced every 4/5k km since ownership (all work carried out by hills motor sport)
GTR Radiator,
Water pump and belts changed at 90k.
3" exhaust all the way through
apexi pod filter
Brass/organic clutch / lightened flywheel, ment to hold 600hp.
bosch 044 fuel pump
front (back hasnt been done as of yet)
all bushes replaced, strut bar/whiteline springs/koni yellow sport shocks/camber kit/sway bars
boost controler
apexi boost gague
rspec turbo timer
ebc greenstuff front pads
GTR front bar
Sound system is very nice, so i'd take that out unless a buyer is prepared to pay for it.
Also has very good alarms in there as well - read 3k.
Abit of a slopey post i know, though please PM any serious offers.
https://www.sau.com.au/forums/topic/14901-expression-of-interest-r32gtst/
Yeh so ive seen, its not really worth selling, mose well just keep it for a pure track car if anything...
Oh well doesn't matter,
im being fkd over by zurich now anyway (1 of their clients smashed my car, taxi at that) so won't have it back for just abit.
Sydney and Brisbane/Gold coast seem to be getting the most for R32's, id be putting it in the paper for $18,000+ (going by whats in the trading post atm) im unsure what sydney dealers are getting, but quite A few in brisbane have $22k+ on there cars (body kit, wheels, zost ect)
$20k for a 32. Wow thats heaps. I looked at about 12 over the last 2 weeks and the dearest being $16k. I found a few at $13500 turbo manual with wheels exhaust, suspension and around 80,000kms. Ive ended up buying a 93 R33 GTST with new Enkai wheels and tyres, HKS struts and springs, Blitz twin pipe exhaust, momo race steering wheel, timer,72,000kms and standard engine for $15800. Seems like i got a bargain :P The car is a grade 4.
Michael...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
