Ok, so I'm thinking ahead about what FMIC I'm going to get. I was originally thinking a Trust (Greddy) V-SPL because I didn't want to go cutting a hole in the battery tray as I'm pretty sure with this kit the piping from the left passes underneath the cooler and up into the bay.
Now I'm thinking that might not be such a good option because the piping will hang below my front bar (Nismo) and I just get up my driveway as it is with only a few mm to spare. Or will it not hang below?
I just want to know what FMIC people have got, and their opinions of it (pics if possible of piping passing below the cooler before going into the bay would be much appreciated :P )
If I decide to go the other route and cut a hole, will I have to relocate my battery into the boot? ;)
https://www.sau.com.au/forums/topic/149094-r34-owners-with-fmic/
Out of all that crap I only found a few useful posts specifically about 34's :P
I only want info on the R34 because obviously 33's have different standard front bars etc..and I can't really judge anything on a 33? Gah! I dunno..I just wanted different options ;)
So far the ARC seems good, loops behind not underneath like the Trust?
Edited by so_tred
Yeah this topic has been covered several times, but as you can see in one of those posts is my 34 with the ARC cooler which im pretty happy with it, bolts up to the stock piping just need to attack a bit off the front bar :happy:
im 99% sure the trust cooler you mention you have to cut where the battery tray is i reckon your thinkin blitz, i have blitz on my 32 there really good and in my case and i cant see your case being any different the bottom pipe sits higher than the bottom on the front bar.
also i have bottomed out to the shit house and cracked my front bar and havnt touched the cooler pipe.
havent got one scuff mark on it.
why dont u just cut a hole? and why is that the r33 battery is in the boot and the r34 isnt?
Don't really want to cut a hole because I don't want to have to relocate my battery & I do like the standard look of the pipes coming up the same way..
However one benefit which I'm thinking of doing the batter tray cutting is I'll have a spare cut where I could put some piping for a cold air induction..
Yeah this topic has been covered several times, but as you can see in one of those posts is my 34 with the ARC cooler which im pretty happy with it, bolts up to the stock piping just need to attack a bit off the front bar :(
The piping goes behind & not under? Just trying to figure out cause I've seen pictures with the tank end curling under.
I just put a ARC kit on my 34 and the fit is perfect the pipe loops behind not under so it doesn't hang any lower as for the core size its bigger than the hole in my bar anyway. Go buy a arc kit you wont regret it.
I'm definitely liking all the good feedback for the ARC coolers & like the design alot.. Also like the fact that the core is a bit bigger than the Trust one..
Where did people source theirs from? I'm thinking Nengun..but I don't want it to get here not be the exact type I want.. :)
They have a couple listed so I'm not sure which it is..
People that have the ARC kit, did the transmission cooler have to be remounted anywhere else or did it still fit behind?
Edited by so_tred
My one is setup like the blitz, I bought a generic 230x550x75mm core, then ran the pipe back under and to the factory location. Total cost $400 and the pipe is within the confines of the under-body plastic liner. I can only get 1/8th of it warm on a hot day, so definately not undersized either.
<==== see avatar
I've got blitz ones, you just have to mount the intercooler slightly higher to avoid hitting the pipe underneath, my bodykit is actually lower than the piping, so it'll scrape the bodykit long before it can hit the piping..
note that the blitz cooler have aluminium piping not as flashy as astainless, but light and does the work...
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
