Originally posted by sidewaymambo
I need a set of stock brake pads (F & R) even if they are half used...
Cheers,
Phillip
Phillip,
I've got a front set of stock pads with *Jay run's into the other room* about 6-7mm of meat left on them....
Actually, looking at these, I'm not sure if they are stock !! Do the stock pad's have a green metal backing !!!
J
Ummmm, how can I explain this.... The stock pads felt like standard pads, while the EBC's have more intial bite to them.
Bad explaination, sorry :P
One of the reasons I got rid of the stock pads was cause they can be noisey. Sometimes they would squeal when pulling up at the lights. But the front disks were pretty glazed over too, so matbe that had something to do with it???
J
Originally posted by DJ_L3ThAL
if jay's arent stock ill have the stock fronts i can sell to you by the end of this week ( getting some ebc greenies then) so make me an offer :D
DJ - you'll like the greenstuffs :P Just make sure you get the disc's machined too. I got about 20% better braking from them...
yer the place im geting them done say i might not need machining, they'ree inspect when i come in or the brakes and if the discs need it they'll do it but they say sometimes they are still good for new pads (i doubt they'd wanna be dodgy as i'd be back quick smart if i ass-end saomeone coz the brakes they fitted failed to pull me up properly)
all places machine the discs to be safe when they replace the pads.. but they don't necessarily need to do.. then they pull you up on "minimum thickness" requiring new discs costing a lot - i think its the greatest scam in the automotive industry.
Yeah, that's true. I remember dropping my old car off for a tune and getting a phone call an hour later saying that all the pads need replacing and the discs need machining. I told him that I checked them a week prior and that he was trying to rip me off !!!
He's responce - oh, we'll check again, they might be OK then !!!
Anyway, Sidewaymambo - I've attached a pic of the pads I've got. Don't worry, I've got 4 pads, only took a photo of 2 of them :P
if jay's arent stock ill have the stock fronts i can sell to you by the end of this week ( getting some ebc greenies then) so make me an offer :)
thanks..DJ..
I will see what jay can find out for me..really thanks..
jay..would you able to see any print on them? just want to make sure they are soft enough..thanks..
I might start a quick thread in the maintanace section to see if anyone has seen stock pads before. I'm nude on this, not sure if they are stock or not - I presume they are though.
There isn't any brand name stamped on them (if the were apexi ones etc, I'm sure it'd have their name stamped all over them - damn rice) :)
The numbers that are stamped on them are 6GXu 236M.
I'll see what I can find out.
J
I haven't had any luck yet with trying to confirm that they are factory pads :P
I've done a search around to see if I can find some pics on the net of stock pads, but again, no luck :D
Not sure what you want to do ???
Cheers
Jayson
mine are definitely stock pads (my car was 100% stock when it came in, ecu wasnt even touched so i doubt the pads were lol) so umm yer im taking my car in tomorrow to get brakes done so ill have them from tomorrow onwards (this is only the front ones)
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
