Hi Guys!
Im selling my Intercooler Piping which came off my Hybrid Cooler kit.
Selling because I have made custome pipes which connects to the standard cooler pipes.
The Hybrid Piping is the typical piping which goes over the engine fan, and also has a custome nipple for boost controller. Its in good nick with minor scratches from installation. This piping is for 600 x 300 x 76
Im only selling the complete piping with NO clamps or hoses.
If you wants pics give me a pm.
Pick up only in melb only.
Selling for $120
give me a call on 0421 111 542. Cheers
https://www.sau.com.au/forums/topic/149245-hybrid-intercooler-piping/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
