my R33 GTST has a recaro driver's seat that I can't slide back far enough.
Before I pull out the seat to have a look, has anyone had experience shifting the seat on the rails?
It looks like it "could" be mounted much farther back.
I want to keep the factory wheel with airbag so a smaller wheel is not a great option
cheers
mike
https://www.sau.com.au/forums/topic/149341-recaro-seat-in-r33-gtst/
  • 3 weeks later...
I pulled out the seat on the weekend.
The seat itself bolts to two steel plates - one on each side. One of these has the seatbelt buckle attached.
These intermediate plates then bolt to the bottom rails, that has the adjustment and bolts to the floor.
I had two options
1) Move the seat backwards on the intermediate plates. This only required 6 holes to be drilled in the intermediate plates (3 each side)
2) Move the intermediate plates backwards on the bottom rails. This required 6 holes but they needed to be tapped for a thread (two different sizes)
I went with the first option and managed to move the seat back about 55mm without compromising the position of the seat belt buckle. Even though the seat belt buckle is 55mm forward from where it was my fat gut means it's still in an appropriate position.
It's changed the whole feel of the car, as I can now use the wheel without my legs being in the way, and heel toe on downshifts.
Looking forward to the track day on 2 Feb. :)
cheers,
Mike
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
