  • Replies 135
Posted Images
Yeah ! been waiting all year (only go every second year) Should be good this year lots more cars entering apparently. More and more imports etc. every year now. Was thinkging about taking my car in just to drive around but it is super stessfull a mate of mine ended up just gettin his g/f to drive withle he got on the piss just so he would'nt care about people touching the car etc. (old skool ford ute). A bit of a cruze on the friday might be fun !
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2787822
It's pot luck i guess. I normally take the line but park away in one of the far off car parks for a little bit of peace of mind... If it isnt some bogan who just doesnt like jap crap or some theif who likes the look of a line either way i personally don't feel comfortable at summernats. Braddon is a little different there are so many jap cars out there at times they almost out number the big aussie cars :)
do u think it will be that bad
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2787999
Do you really think it will be that bad to have a skyline (crazy graphics all over it) in the car park. Being ACT peoples you would probably know best. I haven't taken an import to nats before...
Maybe I'll catch a bus from the room....
Any good places to 'cruise' around ACT for some action....
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2788646
i probably wouldnt take the car then, summernats isnt exactly rice friendly. ill probably drive the silvia there, only because it doesnt really stand out from the crowd.
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2788899
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
