  • Replies 135
Posted Images
ok, so whats the go for this evening? i suggest meet up at the museum between 6pm and 6.30pm, then head into braddon at 6.30pm SHARP to be sure we get good group parking, but whether it'll work that way or not could be another story....
sound like a plan? any suggestions for parking?
Works for me Luke
Parking...... yeah. Um..... yeah.
I spose 6:30 is early enough to get some good spots in Lonsdale street somewhere, but if the police start going over everything with a fine tooth comb like last night?
i reckon your car will slip under the radar tonight. there will be much more 'defectable' looking cars than yours getting around. besides, your car isn't actually 'defectable', as in your tyres aren't bald or car sits too low etc.... just flash your engineer's certificate and i'll reckon you'll be fine.
also just posted this up in the NSW section, so we might get some interstater's there tonight....
I'm not particularly worried about my car especially, just last night they basically went through everything. Mine was parked out in the open with Leigh & Steve's and we got in and out fine. I just don't want anyone's night to end on a downer :)
We're a well behaved bunch, we should be fine.
You are pretty much GAURENTEED they will be doing the same thing tonight best idea is to meet at museum then just cruze and park somewhere a little less crazy and obsever the action.. I went and got new rear tyres this morning cuz i was worried :P
p.s. did anyone see the drags in hume and on monaro hwy last nite.. :P NUTS
Are they still doing that? I rememeber seeing that about 8 years ago but thought it would have surely ended now.
Maybe parking where Mark, leigh and I did last night would be a good spot. It was the street between northbourne and bradden main street?
was behind widebody heading towards exhibition park this morn, man that thing suprises me everytime i see it, its huuuuge!!
Summernats was ok today, abit boring, dont know how people spend all day there, i get bored after a few hours. ill be working there tomorrow and sunday aswell so if you see me say hello, itll get you a free beverage :dry:
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
