Well I had Redline put into my box.
Just drove the car in after a 5 min drive from work.
Jacked the car up on stands - shoved a pan underneath and out it drained - the oil complete with cool gold colour sparkles came out lukewarm.
Needed a handpump to push the oil UP into the gearbox. Too a little over 3 litres.
T.
tony i think they are talking about automatics man..... what u do is..... with the car at operating temp and still running.... put your foot on the brake and pull it into first then neutral then reverse a few times leaving it in gear for a few seconds each time then into park then check should be on the full HOT bit on the stick......u will have to look hard as old trannie fluid is hard to see...... and another tip if your oil smells like its burnt take it to an auto transmission place and get the trannie serviced/checked/change fluid........ hope that helps u out.....:uh-huh:
I think various makes and models are different, some are checked in or out of gear, hot or cold. But the way we did Falcons and Lasers etc when I worked at a Ford dealership is with the engine warm, in drive, with air con on. Not sure if that's "normal" or not. From memory the difference is not all that great between all the above variables.
Originally posted by WHITE R32
with the car at operating temp and still running.... put your foot on the brake and pull it into first then neutral then reverse a few times leaving it in gear for a few seconds each time then into park...................
hahaha.... isn't that a bit over the top?
Motor at running temp,
car in neutral.
Wipe stick
Put stick back in hole,
Read fluid level,
Repeat (to make sure that it was accurate)
Pffffffff men....
Have to make everything so complicated. :D
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
