  • Replies 55
Yeah, I hate that to...
Do you have the front lip for it still?
I do have the lip, I took it off as it has been hit by the previous owner and has been repaired with a plastic weld and didn't quite sit exactly right (as noticed earlier in this thread). I took it off planning to buy a new one, then left it off as it is easier to negotiated gutters, speed humps etc without it. I still have it though, yes. :action-smiley-069:
Luck would increase if my PM was answered :)
Apologies I have been flat out last couple of days. I will try to get your photos tonight! :laugh: Almost 100% on it.
Oh, and all PMs sent peeps. :laugh:
hi again, dont know if you got my last PM - but good luck with the other two people trying to sort out a deal with you.
Just incase you dont strike any luck with selling, I'll keep in touch over the next few months anyway - because i am serious about buying a gtr - but am not in any rush because more and more seem to pop up every day and i dont want to regret what i buy!
this is a car which i would eventually like to try work out a deal for - whenever you are interested, or if you are out of luck with asshole tyre kickers (im also selling a car.. and know how annoying it gets) but in the end if you want to sell - i want to buy.
talk to you soon!
thanks,
chris.
Compression test results: 1-150, 2-147, 3-147, 4-147, 5-150, 6-147.
Vehicle went through a full mechanical and panel beater/chassis inspection with flying colours for a buyer that has dissappeared. Gutless, you'd think it would be decent to at least tell me before or perhaps even after you fu(k me around hey?
Ah the joy of it all. :P
Edited by GT-R32
PMs sent.
I posted the offer of $22.5k up to show it was way off the mark, althought interest is appreciated, please no more ridiculous offers on a car like this. I am by no means desperate to sell, especially not for $8-10k less than what it is worth. The car will sell itself, it is one of the finest examples out there. If you don't have the money, perhaps look at older/worse examples, lesser and/or older models or something else so we don't waste each others time. :laugh:
hi matt, just keeping in touch :domokun:
in your last message - are you refering to the 2 guys you were trying to sort out a deal with? (you mentioned them in our last pm)? im guessing things didnt work out well when it came down to the cash part?
im still interested in the car and watching your thread :rant: please keep me updated - would love to start organising a quick and easy deal that works for both of us as im ready to make a purchase!
thanks again mate :ninja:
chris.
Edited by 350z
Thanks Chris, no those other guys are still on the go. It is the people who have nowhere near the amount asking that offer $10k less that I am referring to.
PMs sent. :P
pm replied - sorry we cant work out a deal :D would have loved to as its exactly what im looking for.
anyway best of luck with the sale (if you do want to sell it!?) :(
thanks anyway
chris.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
