Hey all,
Ive purchased myself a turbo back exhaust system for my r33 and so ive been doing a little reading to get my self prepared for the install.
I just read the the diy section tutorial about installing a split dump pipe off the turbo and the author leads you to believe that whether you use a new or reuse and old gasket you need to use some sort of sealant (exhaust goo/cement).
I just need some clarity because i thought if your using a new gasket, that is what makes the seal between eg. the turbo and the dump.. and exhaust goos are for when ur gasket is broken or not using a gasket at all?
Cheers
Cam
https://www.sau.com.au/forums/topic/150187-installing-new-exhaust-system/
I wouldn't use any gasket goop on the exhaust. I use ordinary grease. The idea is that it burns when you first take the car for a drive (so don't be scared of a lttle smoke at first) then this leaves the carbon residue which fills the gaps.
Thanks for the responses peeps!
So is repco the easiest place to go for this stuff? and do i need to be putting it at every join or is it just the high pressure at the turbo?
Does anyone know any brands/names aswell or should my friendly repco staff member know what i'm talking about :)
Cheers
Im still not quite sure what i should do about this whole gasket situation after speaking to a few companies
Sumo performance say they always use some sort of gasket goo
RE Customs say sometimes, depends on the type of gasket.. wat eva that means
and Brighton Nissan say just use the gasket on its own....
oh and has chasers motoworks changed its number coz the number i called says its disconnected :)
I guess its more so what i should be buying coz there are so many options but most of them say they are gasket replacements...not necessarily to be used in conjunction with gaskets.
or there is the exhaust cement that the dude mentions in the dump pipe tutorial?
i picked up a gasket from nissan today (from back of the turbo to dump pipe) and it has no goo on it but nissan recon thats all ya need to seal..?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
