Hey all,
Ive purchased myself a turbo back exhaust system for my r33 and so ive been doing a little reading to get my self prepared for the install.
I just read the the diy section tutorial about installing a split dump pipe off the turbo and the author leads you to believe that whether you use a new or reuse and old gasket you need to use some sort of sealant (exhaust goo/cement).
I just need some clarity because i thought if your using a new gasket, that is what makes the seal between eg. the turbo and the dump.. and exhaust goos are for when ur gasket is broken or not using a gasket at all?
Cheers
Cam
https://www.sau.com.au/forums/topic/150187-installing-new-exhaust-system/
I wouldn't use any gasket goop on the exhaust. I use ordinary grease. The idea is that it burns when you first take the car for a drive (so don't be scared of a lttle smoke at first) then this leaves the carbon residue which fills the gaps.
Thanks for the responses peeps!
So is repco the easiest place to go for this stuff? and do i need to be putting it at every join or is it just the high pressure at the turbo?
Does anyone know any brands/names aswell or should my friendly repco staff member know what i'm talking about :)
Cheers
Im still not quite sure what i should do about this whole gasket situation after speaking to a few companies
Sumo performance say they always use some sort of gasket goo
RE Customs say sometimes, depends on the type of gasket.. wat eva that means
and Brighton Nissan say just use the gasket on its own....
oh and has chasers motoworks changed its number coz the number i called says its disconnected :)
I guess its more so what i should be buying coz there are so many options but most of them say they are gasket replacements...not necessarily to be used in conjunction with gaskets.
or there is the exhaust cement that the dude mentions in the dump pipe tutorial?
i picked up a gasket from nissan today (from back of the turbo to dump pipe) and it has no goo on it but nissan recon thats all ya need to seal..?
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
