Been looking at some new Enkei rims for the Series II and have narrowed it down to the BXM2 or the RPF1.
Having spoken to wheel and suspension people, they have all said that only 17" rims in the BXM2 will fit and the 18" ones won't fit.
Haven't been able to find out what the offset is for the BXM2's but did find the sizes for the RPF1's which are:
17x7 +45
17x8 +35 or +40
17x9 +35 or +40
18x8 +35
18x9 +35
The OEM rims are 16x7 +40 with 225/50x16 rubber
My understanding is that as far as rolling circumference goes, the closest match would be 17x7 with 225/45/17 or 18x9 with 245/35/18 rubber so the only issue would be rubbing due to offset.
Seeking advice on whether the 18's would fit and for those that have 18's what the offsets were (the previous rim and tyre threads mainly talked about tyre sizes and rim width)
Pics of the rims attached
Any help would be appreciated.
Cheers, Al
BXM2
RPF1
https://www.sau.com.au/forums/topic/150297-enkei-rims/
My Series II was complied with 225/50R16's.
I had fitted Speedy Envy Mk II 18X8 wheels which have a 38 pos offset.
The wheels were fitted with 235/40R18 Goodyear Eagle REVSPEC RS-02 tyres.
Even with SK Group Buy on suspension I had no rubbing or other issues.
your rolling diameters (for comparison) are:
225/50R16 - 631mm,
225/45R17 - 634mm - 3mm o'size,
235/45R17 - 643mm - 12mm o'size,
235/40R18 - 645mm - 14mm o'size, and
245/35R18 - 629mm - 2mm undersize.
In the ACT you can legally fit a wheel/tyre combination to your vehicle as long as it is not over/under size by 15mm. As can be seen with the above combinations - they are all legal.
Why fit a 245/35R18 tyre? This is not a common tyre and would cost nearly twice as much as the far more common 235/40R18 fitment!
My Speedy wheels may well be for sale - if inteested pm me.
https://www.sau.com.au/forums/topic/150297-enkei-rims/#findComment-2800398
Thanks for replies
So if I get this right, as long as I went for something with an offset in the range of say +35 to +45 (ie 5mm either side of OEM) then this should be okay?
ie say 18x8 with +35 should fit
The only reason I put the 245/35/18 on there as that is the closest tyre size for rolling diameter to the original sizes
All I need now is to find out the offset on the BXM2's
https://www.sau.com.au/forums/topic/150297-enkei-rims/#findComment-2801010
Found this: http://www.1010tires.com/WheelOffsetCalculator.asp
very handy (if it is accurate)
going from 7" +40 offset to 8" +35 gives you 8mm less clearance on the inside and extends 18mm further on the outside.
Sounds like the goods to me.
Cheers
Luke
https://www.sau.com.au/forums/topic/150297-enkei-rims/#findComment-2803599
Cheers
Luke
What sort of tolerance is there to play with clearances?
Thanks for the offset calculator
https://www.sau.com.au/forums/topic/150297-enkei-rims/#findComment-2804748
i've had 19x8.5 enkei rp03 at 22p offset on. sat flush in the rear, and under the guards up front by about 6mm. on coilovers with standard guards, no rubbing.
i now have 17x9.5 sparco at 35p with 5mm spacers on rear and 20mm on front. it's hella flush with the guards and looks tuff.
https://www.sau.com.au/forums/topic/150297-enkei-rims/#findComment-2809749
Was doing some more searching today including the excellent 1010 Tires site and came across Meggala's site with a listing of wheel and tyre sizes
I had forgotten about Meggala's site as he was active on SAU years ago
Here is the link:
http://meggala.com/wheelsoffsets.htm
https://www.sau.com.au/forums/topic/150297-enkei-rims/#findComment-2815507
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
