FOR SALE ARE THE FOLLOWING ITEMS: ITEMS DESCRIBED AS PICKUP ARE LOCATED IN ST GEORGE AREA OF SYDNEY
3) GENUINE NISMO FRONT PIPE FOR R32 GTR:$350$300 PICKUP ONLY
5) R32 GTR GENUINE NISMO FRONT STRUT BAR: $290$250 incl post
6) R32 GTR CAM GEAR COVER: $90$70incl post
8) R32 GTR CENTRE CONSOLE WITH LID AND HANDBRAKE BOOT: $180 $160incl post
9) R32 GTR CENTRE GAUGE SURROUND WITH CIGARETTE LIGHTER AND GEAR BOOT: $100 incl post
10) R32 GTR FRONT SEATS (with rails): $750$700 PICKUP ONLY
post-29722-1168151225.jpgpost-29722-1168151512.jpgpost-29722-1168151479.jpgpost-29722-1168151460.jpg
11) R32 GTR BACK SEAT: $300 $250PICKUP ONLY
13) R32 GTR GEARBOX 45,000 KMS: $800 $750PICKUP ONLY
14) BLITZ SBC i-COLOUR ELECTRONIC BOOST CONTROLLER (1 MONTH OLD): $800$700 incl post
18) TURBOSMART SUPERSONIC DUAL TRUMPET BLOW OFF VALVE: $300$200 incl post
Edited by GTRGTR
  • Replies 46
Posted Images
Hello
Just checking if you still had the GTR coil pack cover and if the price had dropped from $150
As well do have a set of of coil overs or oil pressure sensor.
Cheers :)
