Hey all, im installin a 040 fuel pump ito my R32 gtst, i have modifyed the bracket and wires to take it all,
my prob is now the whole assembly is to long by about 2cm, how do i get aroud this,
The only way i see it happening is if i cut down the zinc coted pipe that conects to the top of the pump ,because the top of the pump and bottom of the pipe are pushed up to each other,
something i would rather not do, if there is another way around
Can someone please help or post a link to pics or a write up of someone here who has done this,
Thanks
You have to cut the pipe, theres no other way. You also need to make sure the pump assembly is the same length as original. If its too long, and say the pump is sitting ON the bottom of the tank, thats no good becos then there will be no room for fuel to actually get into the pump!
