Hi SAU yes i had to lol when i read most of the DOSE answers spose you ask you get, #1 would like to know what is the next size up injectors to use from the standard ones on a r32 gtst plus what should i pay for them? #2 is paying $600 for splitfire coil packs about right ? #3 what should i pay for an ECU remap? the reason im asking is that i have splutter probs thought it was dirty plugs or dirty AFM so cleaned those changed fuel filter check fuel pump now im down to two things that a coil is f#$%%#@ or an injector has shit itself ,the splutter can occur at anytime hot or cold but doesnt happen when a mechanic looks at it (f$@##@%$$% ironic) so if im going to change all of these i may as well look at a few more kw's ehh anyway some direction would be great ,my car has compressor chop from no BOV doesnt DOSE LOL :thumbsup:
What's the spark gap set to. 0.8mm is what most people need to run.
see if that helps.
But
1) next size ar 440cc from memory
2) Splitfires are $589 delivered throug Sliding Performance
3) Dr Drift remap is about $400 i think.
see if that helps.
But
yeah have regaped from 0.8 to 0.7 and still same prob
Before you buy coils etc and other things.., try another AFM. I know you have cleaned but trust me it could still the AFM. It sounds exactly like the problems I had when my AFM was farked.
After i cleaned the AFM it would be good for a bit then would mess up again. Another second hand AFM fixed it right up.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
