hey guys.
ive noticed recently, that everytime i wash my car and chamois it, it leaves stains on the paint work, and the only way you can get rid of it, is to poilish it out. :whistling:
as i said, its only been happening since december, after i took it to a place to get washed.
any ideas?
re-spray is on the cards, but what can i do in the meantime? cbf polishing it all the time..
and if you want pics, i might be able to organise some..
car is a Black r32 gtst..
thanks in advance.
jarryd
EDIT: could this be caused by carwashes usuing recycled water?
i might have to do a test at home by using tap water.
f**king water restrictions.
https://www.sau.com.au/forums/topic/151135-white-stains-on-paintwork/
I have a black R33 - dark coloured cars show water stains and residue a lot more than lighter coloured cars.
I find that washing the car in sections and rinsing helps prevent the stains appearing (ie: wash roof and windows - rinse car, wash mid section - rinse car, wash lower section - rinse car). Also the sooner you can get the water off the car with a chamois after washing, the better
If you've still got marks, you could try using Meguiars Quick/Speed Detailer on a cloth and give the car a wipe over...
strange, perhaps its the polish your using or they used.. dried white not clear? hit it up with some tek wax and see how she comes up
i use tech wax to fix it up lol
its kinda dried on. ill try get some pics up.
yeh try some diff cleaning products and see how thtgoes.
i only use meguiars, so i dont think thats it...
is it all over the car and consistant...if only in certain areas maybe somethin has landed upon ur car like a chemical or something...or maybe some1 has sprayed ur car with something nasty
dunno wat else it could be, if it was polish is should be polished back of for "good" once u re-polish the car, only thing else i could think of is maybe after a polish u missed certains spots...left it in the sun and the polish has so to speak "baked" itself onto ur paint , then once u polish it off, the new polish shins it over until its fully come off/sprayed off with water
Edited by Ricos
Yeah thats weird then dude... Real upsetting actually..
maybe hit those spots with a buffer next time? strange if you ask me .. Make sure you hose of excess soaps quickly and always wash your car early morning or night to avoid mid day temps to evaporate valuable leftover water (leaving marks)
hmmmm....must have been this place i took it to then...
but what can i do now, when it happened i took it back the nextr day and they polished it out.
it sucks.
well, re-spray is coming sooner then hey..
thanks for your help ppl
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
