Hey,
I have a few bits and pieces that I no longer need so I'm putting them up for sale - if anyone is interested in any of the items, you can leave a message here or PM me and I'll get back to you.
I am also willing to take reasonable offers.
Item One:
Sports Steering Wheel (No Boss Kit)
SOLD
Item Two:
Nissan Skyline R33 Series 1 Standard Coils. Item is in good condition.
I'm Looking For $160 O.N.O
Item 3:
Nissan Skyline R33 Stock Front Bar. Item is in good condition.
SOLD
I am located in Brisbane's Southside, if you would like to inspect any of the items your welcome to do so, PM me and we can arrange a time. I have no need for these items anymore so I am open to reasonable offers.
Edited by GTS793
https://www.sau.com.au/forums/topic/151760-looking-for-a-quick-sale/
Steering Wheel and Front Bar is now sold. I need the coil packs now to be sold, they came off a R33 but have been told they are the same as a R32.
Good for a spare or if you have a misfire a coil pack may be the problem.
I'll take any offers on the coil packs now, so leave a message, PM, SMS or call me.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
