FOR SALE IS MY 1992 180SX SR20DET
SELLING DUE TOBUYING A HOUSE AND THE MISSUS SAYS MY TOY NEEDS TO GO!
CAR OWES ME OVER $35,000++
56,000KMS 2ND OWNER IN AUSTRALIA 1ST OWNER BROUGHT THE CAR BRAND NEW IN JAPAN AND BROUGHT IT OVER WITH HIM WHEN HE MOVED HERE
BEEN OF THE ROAD FOR A YEAR FOR GROUND UP REBUILD
+++ CAR HAS AUSTRALIAN COMPLIANCE AND HAS BEEN PREVIOUSLY REGISTERED+++
NEEDS BLUE SLIP FOR REGO
FOR BLUESLIP REQUIRES
FRONT SEAT BELT BUCKELES
FRONT BAR FITTED
HEADLIGHTS WIRED UP
CAR HAS MADE 248RWKW AT 16PSI TUNED BY CROYDON RACING
NOW HAS MICROTECH ECU
EXTREME HEAVY DUTY CLUTCH WITH A MONSTER LOAD RATING AS THE EXCEDY ONE FAILED ON THE DYNO WHICH WAS BRAND NEW!
NOTHING TO SPEND ON THIS CAR AT ALL IT'S ALL DONE!
ENGINE:
GT28R BRAND NEW
PIRTEK BRAIDED LINES
B&M OIL COOLER WITH BRAIDED LINES
TUNE AGENT STAINLESS STEEL MANIFOLD
CHROME ROCKER COVER
CHROME OIL CATCH CAN
CHROME RADIATOR OVERFLOW
S15 RADIATOR
TWIN THERMOS
HYBRID GT SPEC INTERCOOLER
ENGINE FAN REMOVED
SARD 850CC INJECTORS
FORGED PISTONS
NEW RINGS
PRETTY MUCH OTHER THAN THAT STD REBUILD
NEW CLUTCH
MACHINED FLYWHEEL
BLUE WIRING COVERS
ALL FUSE BOXES REMOVED FROM ENGINE BAY ALL HOLES SMOOTHED
G-REDDY INTAKE PLENUM PAINTED SAME COLOUR AS CAR
NEW WATER PUMP
DUEL STAGE BOOST CONTROLLER
MICROTECH LTX8
3" TURBO BACK EXHAUST
NISMO STRUT BRACE
EXTERIOR:
16" AME CHROME WHEELS
VERTEX BODYKIT
FRONT BAR HAS CLEAR INDICATORS FLUSH MOUNTED
REAR WING DELETED
CLEAR VT STYLE SIDE INDICATORS
HOUSE OF KOLOR KANDY BLUE TO AQUA IN DIFFERENT LIGHT BARE METAL RE-SPRAY IN AND OUT
NEW WINDSCREEN
NEW RUBBERS
HANDLES AND MIRRORS ALL COULOR CODED
NEW LOCKS THROUGH OUT
SUNROOF
SUSPENSION:
JIC REAR COIL OVERS
HKS FRONT SHOCKS AND SPRINGS
ADJUSTABLE CAMBER ARMS
INTERIOR:
S15 FRONT SEAT NOT A MARK ON THEM
AUTOMETER 2 5/8" BOOST GUAGE
DIGITAL HEAD UP DISPLAY ALL WORKING!
DARK GREY AND BLACK INTERIOR
AFTERMARKET STEERING WHEEL
CLIMATE CONTROLL
POWER MIRRORS
CENTRAL LOCKING ECT..
CAN ALSO HAVE THE TAN INTERIOR FOR EXTRA COST WILL NOT SELL SEPERATLY UNTIL CAR IS SOLD! BUYER HAS 1ST CHOISE ON IT
TAN CARPET
SWADE ROOF LINING
SWADE MATERIAL FOR SUNVISERS
ALL PLASTICS TAN
MATERIAL FOR TRIMMING THE SEATS INCLUDED
DOOR TRIMS ALREADY TRIMMED
CUSTOM DASH WITH 3 2 5/8" HOLES FOR AUTOMETRE GUAGES TAN TRIMMED ALREADY
ALL DASH PLASTICS SILVER
LOOKING FOR AN EXTRA $2000 INCLUDES SEATS TRIMMED
OR $1500 SUPLY MATERIAL ONLY NOT SEATS NOT TRIMMED
++TAN INTERIOR NOT FITED! AT THAT PRICE++
ANY QUESTIONS FEEL FREE TO CALL 0417826725 OR PM ME!
WILL ALSO GET A GOOD UTE LOAD OF SPARE PARTS TO GO WITH CAR IF WANTED
PRICE IS $18,500 ONO WILL SWAP FOR CAR OF INTEREST JUST PUT IT UP HERE DETAILS AND PICS WHETHER STRAIGHT SWAP OR CASH MY WAY
LOCATION OF CAR IS CAMPBELLTOWN NSW AUSTRALIA!
Edited by SXY
hey mate, juts wondering how you got 248rwkw's
one of my mates owns an 180sx as well,
he has the sr20 with gt28/71 turbo (bigger then yours), power fc computer, 3" exhaust, front mount intercooler, pod filter, 550cc injectors, 500hp walbro fuel pump, z32 air flow meter, bov, and he made 292rwhp at 16psi
cheers jai
Edited by jap80x
cheers jai
power fc tune could be very safe, z32 restrictive mine doesnt have a airflow meter, 500cc smaller than mine 850cc, ive got aftermarket plenum, differnt exhuast, different manifold, his engine might not be as fresh, mine has cams and valve springs unsure as was of actual spec as they were in car when i got it, different mods and brands of item will differ performance
biggest differance all engines are differnt even from factory they will give differnt power readouts on a dyno. second all dynos are differnt he could have went some where with a lower ready dyno, mine could have been done at a higher reading dyno, quater mile times are the only way to test a cars speed truly but these cars where made for drifting so depend what your after in a car in the end
hope i help answer your question
Edited by SXY
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
