VERTEC VR5 MANARAY SPORT 18 INCH DEEP DISH RIMS 5X114.3 $2200 - 90% PERFECT CONDITION - MAY SWAP FOR OTHER RIMS
FRONT:18X8.5 235/40 - 90% TREAD LEFT INNER CAMBER WEAR
REAR: 18X9.5 265/40 - 90% TREAD LEFT PERFECT
CONTACT:0421737768
Edited by kr4zie
https://www.sau.com.au/forums/topic/151854-vertec-vr5s-18-inch-deep-dish/
need to know 100% what the offsets are. I've had a set of exact same rims on my car but with +45 as the rear off sets an didn't clear the rear brakes on my 33. As well as sticking out of the geard a few mm. The set i tried on my 33 came off a black drift 180sx.
I went and tried these on my R33 gts-t today...
Great condition rims and look great.......
This is what I found:
the rims are +45 front and rear offsets, so they hit calipers on a 33 gts-t on both front and rear, would need to run 5mm spacers both front and rear to fit them.
also both front tyres are completely bald on the inner edges, to the point that one wont even hold air. So the need 2 new tyres on the front. Rear tyres have near new tread on outside edge with about 2-3mm on the inner edges.
just thought people should know what I now know.
good luck with the sale
  • 5 weeks later...
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
