sorry guys but i dont know where this thread belongs, im just curiouse is there one device that does them all because i really cant be stuffed fitting 20 different units in my car. I know most people like that look because it makes things look more hi tech or what ever, but personally i like neat. any idea's
  • Replies 60
1. You dont need a turbo timer, do a search, SydneyKid has already clearly outlined why.
2. You have only listed 3 things there, I fail to see where the other 17 units are..........?
3. I dont believe this unit you are after, the all-in-one, exists....?
Ha just what i like to see positive input with out sarcasm
absolute ledgend SKA
cheers AlexCim
Yeah I have a TT too, came with the car, used it for a while but now just set it to zero, still it shows my boost, albeit in bar, still it is a bit useless.
And I am not tottally against them, but if you read the following thread, you will see why I believe they are not worth buying.
http://www.skylinesaustralia.com/forums/in...t&p=2309803
No offence to anyone that has a TT, but they seem like RICE to me... Your car won't cool down sitting still while running, you need to drive it around slowly so the air flow can cool it. Ever noticed on a hot day that your car gets warmer sitting at the lights, then cools down once you start moving again?
That is the whole explanation (in a nut shell) to why they are not worth having. And that they are a great place for a car thief to hot wire the car from...
Cheers
Luke
All in one, no
but boost and engine management can be controlled in 1, PFC with BC kit. However...forget that idea.
Wolf ECU has a built in boost controller and possibly a turbo timer, also SK said to me he his first choice for EBC with a Power FC is the standard BC kit.
I think Alex is probably pointing to the Auto/no PFC issues there. It would be great to have the management know what the boost is doing, I think that would help a lot.
I guess we will all have to settle for "different strokes for different folks"
Absolutely! You want one, get one, just stating why I wouldn't have one. Freedom of information, all good.
Cheers
Luke
cheers darrinspencer
did a bit of poken around on the wolf v500
http://wolfems.cart.net.au/details/635751.html
but half way down the page is says "Turbo Timer support "
does that mean it supports "your" current turbo or that its built in?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
