Has anyone got any ideas about this one.
Imported my R33 GTS 25T about 6 months ago and for the last two tanks,
the gauge has been playing up. It shows Full on the gauge until I've done about 270+ kays, then it falls sharply until it hits the Empty mark by about 420 km!
Have made no changes to car and it has only done it this time and last time! Could it be electrical??? Could it be something inside the tank?!?
The only thing I can think of that I did differently during the first tank was I really "gave it some" up a twisty section of road, through tight bends and chicane-type corners when that tank was still full (only about 3 km!). Any clues??? Don't really want it to be like this permanently!!!
iijj
https://www.sau.com.au/forums/topic/15234-crazy-fuel-gauge/
I had the same problem, the sender has fallen off its bracket and sunk to the bottom of the tank.
Remove the top to the tank (near battery) and find sender and reattach the the metal bracket that supports pump and sender, it will click into place when installed correctly.
https://www.sau.com.au/forums/topic/15234-crazy-fuel-gauge/#findComment-310771
Its easy to access, remove cover between boot and battery, a metal cover on driverside has 4 screws. remove these and you will find top of tank. Remove wires, unscrew large retaining ring (you may need to use drift and hammer..gentle.. to get it started) then reach into tank and and fish arround for the sender its a long tube like thing and will be on bottom of tank ujust follow the wires. It then clips to the metal bracket vertically.
Warning: Disconnect battery before opening tank as fumes will be strong, do not spend long periods in boot as the fumes will make you feel ill, take regular breaks.
https://www.sau.com.au/forums/topic/15234-crazy-fuel-gauge/#findComment-310803
I had a theory about this for a while....
On my GTS-T I was noticing that if I was really racing the car the the guage will plummet reasonably quickly. As soon as I was taking it easy for a while it would seem to come back up a small amount. It almost seemed to be indicating an estimate based on the consumtion rate rather than what was actually left in the tank. Surely they didn't put any smarts into the fuel guage??
Anyone else notice this?
https://www.sau.com.au/forums/topic/15234-crazy-fuel-gauge/#findComment-310887
same thing happens on my old man's 98 vs commo.......
i've always thought that it was just basing it on an estimation which seemed kind of odd.
https://www.sau.com.au/forums/topic/15234-crazy-fuel-gauge/#findComment-312340
Swallowed most of that! (not the fuel, the info!)
Anyway, I'm a bit hesitant to open up the fuel tank. Sounds
like a recipe for fried eyebrows! Are there any mechanics out
there who can confirm the safety of this solution???
Oh yeah... I'm pretty sure every cars (analogue) guage will
move up and down depending on nose up/down or left/right
turns. I'm no physicist, but if I was I'd call it something like
- I don't know - the "Slosh Effect!?!". I've noticed it in ALL my
cars! Any physicists out there with the actual facts???
Thanks...
iijj
PS
MRE - How did you get into circuit racing up here (costs - etc)? Is yours
a four door, too? What mods for a 14.3?
https://www.sau.com.au/forums/topic/15234-crazy-fuel-gauge/#findComment-314272
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
