ONROADS Dyno day - Hosted by Dr Drift
To celebrate the launch of Onroads.com.au we will be having our very own Dyno Day hosted by our very own Dr Drift.
Sunday 4th March 2007
Venue:
Dr Drift
Unit 5 / 9 Alick Rd
Brooklyn, Victoria
Australia, 3012
Price $40/car includes power run and print out (FWD and RWD cars only)
Prizes
Trophy for the most powerful forced induction vehicle - per litre. (turbo/super charged)
Trophy for the most powerful naturally aspirated vehicle - per litre.
Doing it per litre puts everyone on a level playing field, A 4cyl can potentially win over a V8. :lol:
but as danoz always said THERE'S STILL MORE.
EVERY 3 days from now we will be giving away one free dyno run for the dyno day to one of our members.
How do I win?
From now up until the dyno day members will receive points for signing up, posting and referrals.
10 points - Signing Up
15 points - Making a referral (this can be done in your MYONROADS menu)
10 points - Making a post in the forum
20 points - Making a Post in the PARTS section
Simple, the more points you have the more chance you have of winning a free dyno run at our dyno day!
To secure your spot at the dyno day PM me for payment details. Full Payment must be made prior. Limited spots available. Spectators welcome.
Edited by jungle_s14a
https://www.sau.com.au/forums/topic/152489-dyno-day-onroads-march-4th/
Good to see more of you coming on board.
Anyone who is wanting to come, you will need to pay the $40 up front to secure your spot. We are filling up quickly.
To secure a spot you can email me for payment details at: [email protected], you can also PM me through onroads.
thanks,
David
what time does it start? i start work at 1:30pm on sunday's...
and what are the suburbs around brooklyn? have no idea where that is... besides the new york suburb...
um, Tottenham, West Footscray & Yarraville and maybe altona north?
  • 4 weeks later...
Just over the Westgate Fwy, take Millers Road exit at Altona and a right at the bottom of the ramp. Heads towards the Old Geelong Road, Princes Hwy. That is Brooklyn area. We have a depot there that I frequent.
Sorry to hear about the dyno, not good :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
