Just Engine Management - Dyno Day & Group Buy - Coming Soon 2007
J.E.M Exlusive SAU Offer
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
Posted Images
SAFC tune should be fine but ill verify that asap... hopefully in the next couple of weeks ill be able to get an official SAU group buy for all your dyno, tuning and ecu needs! but as i said prices will depend on intrest so more people = cheaper dyno, tune or custom package...
Cheers
When i last spoke to Adam at J.E.M he assured me that if we can get a decent number of people for ECU & Tune or Dyno Tune he will give us excellent prices. The reason why i setup the poll is to give him an idea of how many cars we will get for a tune... this will determine the prices.
People are spending thousands on performance products and for only 10 - 15rw/kw gain... so it makes more sence to me to get a professional tune for a lot less money and for 15 - 30rw/kw gain as well as reliability...
On the 20th of Feb my car is booked in at JEM for a Haltech E11v2 supply, fit and complete tune for $2800... This may seem alot but compared to other places this is quite cheap...with more cars, prices will be much cheaper...
TUNE HOUSE Quoted me = $3000
UNI GROUP Quoted me = $3200
HITMAN Quoted me = $3200
I got these quotes as a comparisson for you guys, I personally wouldn't let anyone touch my car besides JEM...
I'll be getting the Group Buy organised in the next couple of weeks...
Regards,
Sarkis
The Dyno power run is putting your car on JEM's Dyno.. Get 3 runs with a maximum power print out including:
- AFR
- Torque
- Kms/h
- RW/HP or RW/KW Graph
Adam will also let you know on:
- The general health of your motor
- If the car is running lean/rich
- Tips on what to do next to get your car running better.
Nothing on the car is touched... cause timing alteration .etc. falls under tuning and it requires much more time. So unless you got an aftermarket ECU, its pointless mucking around with little tweeks which will cost you dyno time..
A dyno power pass is MUCH more then just seeing how much power your car is making. Its also an indication of:
- How safely your car is running
- If your car is out of tune, timing or A/F mixtures
- As well as an indication if your car is running at maximum capability.
All that for $50 is peanuts! So lets start getting a list together of who is in for sure and we'll organise a Dyno Day... Maximum of 6 cars per Dyno Day....
Dyno Day #1 List:
1. jeffworld2
2. r32woohoo
3. lastlineofdefence
4. KIRUSS
5.
6.
Regards,
Sarkis
Edited by QRI05E
Thanks for the Positive Feedback stuartr32.. Adam is an exceptional tuner as well as a very honest an straight forward person. So if you want best quality and most friendly service... JEM is highly recommended!
Regards,
Sarkis
i would be in, possibly bringing some of the ctown thread guys, but i am on holidays from the 5-11th next month so cant make it then. if we get 5, can we come as a seperate group whenever we have time?
thanks for giving us this opportunity to do shit cheaply :pwned:
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
