Personally I dont think they would crack if they are of a high quality, its on the exhaust side of things so if you do notice cracking then you can just switch over your stock dumps again and yell at whoever sold you them.
https://www.sau.com.au/forums/topic/152769-brn34-dumps/#findComment-2841157
The BNR34 dumps are stainless already and are designed well. They're equivelent or superior in flow to any aftermarket all in one dump pipe.
If you want to split the exhaust though you're going to go aftermarket. Gains will be small probably or non existant. The stock dumps also have a heat shield if i recall correctly.
If I had the choice between Chinese stainless dumps and standard dumps I would keep the stockers. I went to the Trust long style front+dump design pipes and I think that was a decent upgrade because of the longer split but they don't fit very well to be honest.
https://www.sau.com.au/forums/topic/152769-brn34-dumps/#findComment-2841219
valid point, my friend (a mechanic) said the same, GTR isnt a budget car, and they have done the research etc and upgraded since the 32s
stock dumps and front both have heat shields
and its going to be a big job getting them out
Edited by andz69
https://www.sau.com.au/forums/topic/152769-brn34-dumps/#findComment-2841451
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
