Hey guys, in a few weeks ill be fitting a set of Deatschwerks 555cc high flowed injectors into my S2 R33 GTST. Just wondering, would i need to get a set of new O-Rings?
Currently there are no leaks or residue near the injecor rail so it all seems to be sweet.
Regards,
Sarkis
https://www.sau.com.au/forums/topic/152793-do-i-need-new-injector-o-rings/
Yeah the cost of new o-rings is nothing so they would be crazy not to supply you with a new set as a safe guard.
When you reinstall them make sure you use some vaseline and twist them as you work them back into the rail so you dont nick an o-ring.
www.nengun.com
www.greenline.jp
www.justjap.com
www.otomoto.com.au
Theres a start anyway! :D
BTW: post a wanted ad in the wanted section of this forum aswell as places like firesport.com etc
Edited by Godzilla32
QRI05E,
are you sending your old injectors back for a cash back?
$25 USD each injector thats $190 AUD for a set of 6 you get back.
You pay $519 AUD for a set of 555cc sidefeeds minus the 190aud cash back and thats $329 aud for a set of injectors.. Pretty darn cheap.
Hey cubes, my injectors were shipped today :P and they cost $555 including international postage.
$1 per 1cc lol
Yea i might send my injectors back to them, ill have a few things to sell once all my mods are finished so ill post them up on the FS section and see how they go...
Ill keep you guys posted on how these injectors perform!
Regards,
sarkis
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
