well i think that all of us non silver skyline owners should have a bit of fun with the METAL SKY members and have our own exclusive club called RAINBOW SKY as then we can have all colours and have more members too...... metal sky guys dont get pissed at me im just having a bit of fun im just jealous i cant join...... lol.... :bahaha: :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/15281-rainbow-sky/
