Front and rear Bilsteins for R33 Gts-t complete assemblies with low king springs. Nothing physically wrong with them. The front's feel a little soft to me but may well be related to spring rates. They are not leaking whatsoever! Rear's are in perfect condition. Currently still in car. Happy for people to inspect before purchase. Prefer Melbourne buyer on these but can ship interstate at additional cost. This is cheap as guys, shocks would be roughly 2 years old. Firm ride yet nice and compliant on a daily driver.
SOLD
Apexi Powerfc (no handcontroller) for R33 Gts-t Series 1 in perfect condition -
SOLD
https://www.sau.com.au/forums/topic/152838-all-sold/
I suppose if you are inclined to want to adjust maps slightly or see specific sensor levels etc it is good. Otherwise it is not a real drama so long as you have a tuner who has spare hand controllers. Most decent FC tuners have spare hand controllers for this exact circumstance :P
https://www.sau.com.au/forums/topic/152838-all-sold/#findComment-2857320
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
