Asking people what type of clutch they use ?
Cost of the clutch ?
Labour cost's ?
Rebuild cost's ?
And lastly , where did you get it done ?
sorry dyno results (rwks) would also be worth a mention
all comment's welcome
thanks
Michael :P
https://www.sau.com.au/forums/topic/152881-what-clutch-do-you-use/
I have a exedy twin plate which needs rebuilding or replacement.
Have spoken to extreme clutches (adelaide clutch services) already by the way.
Just checking out other options and opinions. :P
Nismo have stopped making the G Max series clutches. From the success of the Nismo Copper mix single clutch which is the strongest single clucth available that can handle 420 PS. Now Nismo have decided to make the Twin Plate copper clutch to suit most nissans. Rated at 640PS the NISMO Super CopperMix is the highest performance model on the clutch system line. It uses a copper mixture for the clutch disk. The CopperMix is able to handle high horsepower outputs & transmit the all the power to the wheels
Nismo twin plate for BNR32
$1500
exedy 5 puck ceramic
had full faced ceramic extreme, very good streetable clutch. held 205rwkw for 3 years of bashing.
why not do it yourself? i'd help someone. easy job, just needs two people. f**k payin some bastard hundreds when he'll also take your car for a hammer!
Edited by Ryanrb25
I dont have the space to do it myself and wouldn't know where to start.
I have been talking to Jason who used to work at united subaru in town (he owns a 32GTR vspec s"2) and he lives just around the corner from my work.
He is offering to do the job with a cheaper labour price than where the car has been before(mates rates),
and seems to know his stuff. Might take a bit longer than a workshop but that is alright because I wont get the bulls#@t dribble that I seem to get elsewhere.
Because the car makes close to 300rwks I am been told to keep to the twin plate item's.
My 32GTR has the 33GTR box in it because it was one of the last 200 made.
The car has the pull clutch mechanism which has linkages added to convert it to a push type in the bell housing and these will come out and be available at a later stage for some one to pick up (worth $200 secondhand) Might suit a 33GTR owner. :(
Thanks for the offer Ryan if that is what you are saying but after mondays crash, I will have to avoid heavy lifting of any kind for a few month's . Dont want to inflame the torn disc in my lower back from previous accident. :P
Jason from greenline.jp supplied me with my OS Giken twin plate rebuild kit (Kit A), was delivered to my door within 7 days of payment/order for just over $800 ($804 or something)
I then had the guys at ACS/Extreme machine my flywheel and the mounting surface for the clutch cover for under $80 same day service
The twin plate came with a gearbox I bought, and install has been $250 in past, waiting to see what it will be this time as is getting done this week.
I would email greenline and tell them the exact model Exedy twin plate you have and see if they can source a genuine rebuild kit for you.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
