  • Replies 72
The first episode of the week is tuesdays 8 30 but they seem to repeat it at random times during the week, im sure if you had a look in the guide youd be able to watch it at a certian time any day of the week..
the show isn't to bad, but man they could of made it more realistic, like when they steal that atm across the road from the cop shop, that is so bullshit, you would of got fcked over straight away
but yeah hope it gets better......
Edited by MINI BUS
its a top show. all u gotta do is close your eyes and wish that punchbowl wasn't 20min from your house hahaha.
if you put the bullsh*t fake accents (esp. from that asian dude), the glorious life they claim to have its got a really good story line. last nights show was the best, the ending had me on the edge of the seat. if she stopped with the try hard accent shes not a bad sort too.
hmmz ok I just found it on a torrent site LOLz :D
told u we recording it on dvd recorder, can make plenty copies :dry: (for personal use of course)
last nights episode was pretty good, its getting deeper and deeper into the story, half way through now
That dad bloke is absolutely hilarious, "hey you stole my f%*cking mags!"
hahahaha yes I always laugh my ass off at that guy, especially when he's having a sook about his mags.
I think he's the only guy in the whole show who's ace at his role. Can't fault him, his acting is spot on haha
Yea he is pretty good. The asian guy is shit and I also think that head cop guy with the beard is shit, he should be swapped with the other cop who he was giving cash too, because the other cop looks like a hard ass.
correct me if im wrong,but in last tuesday's episode was the chick EC serious about asking that dodgey mechanic to put a turbo WRX engine into her Skyline???
maybe i missed something.
but yeh.i like it,better then home & away.lol
well it "is a nice fresh tight engine" according to her, and the line is non turbo... hey it would be an improvement and definately different haha
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
