  • Replies 73
just thought i throw me two bob in :no: ive had to pull one of my ceffy dashes apart many a time and did notice that all globes have very easily removable green silicone sleeves so its a very easy process to make the dash white blue green etc hooray hooray
ceffys are like the greatest n that ever :yes::D
wwooootttt!!!!
https://www.sau.com.au/forums/topic/153344-i-want-i-want/#findComment-2854730
we need a confirmation though of someone with a spare cluster
as that has digi clock yet white dials...
i dont wanna pull my cluster apart this weekend to find out it cant be done easily or f**k something up trying to do it
and yes 11/10 FTW! p.s. i need my front rimsys here - another week to go :)
https://www.sau.com.au/forums/topic/153344-i-want-i-want/#findComment-2855173
Tools needed:
- Medium sized Phillips head screwdriver
- Small size Flat head screwdriver, or similar flat tool for bending tabs.
Time taken, 30mins tops, most likely 15mins.
I am completely trashed after a full day of drinking, so it took me 15 mins just to remove cluster.
There are 4 screws in the cluster surround (the bit with air vents).
There are 4 screws holding the cluster in, and 4 plugs connected to the back of the cluster (probably 3 or 2 if you have factory manual).
Once the cluster is out, and in your hands, clear a space on your work bench (or equivalent area).
Looking at the cluster, you will see the clear cover has 4 tabs at the top and 4 at the bottom, push these tabs in to remove the clear cover.
Don't fiddle with the gauge needles, you will probably put them out of calibration!
Then there is another plastic surround, also 4 tabs at the top and 4 tabs at the bottom, remove this too.
You will now see the individual gauges and if you look hard enough, you can see the green sleeves around some of the bulbs (1 either side of the speedo and tacho, making total of 4).
The sleeves are difficult to get to, so you need to remove the gauges completely.
Looking at the back of the cluster you will see 3 bolts behind the tacho, remove these.
Lift the tacho carefully from the cluster.
Now you have full access to 2 of the green sleeves. Use your flat head screwdriver to get the sleeves out of the cluster.
Reinsert your tacho into the cluster and replace the bolts into the back of the tacho, there are 4 holes for bolts. Put 1 in each side and 1 in the top.
Repeat the same process for your speedo.
If there are any marks on your gauge face plates or clear cover, wipe them clean, then replace the plastic covers.
Replace any bulbs if you removed them.
Plug the cluster back into the car and screw it in place.
Test it works properly.
If all is good replace the cluster surrond and screw it in place.
You may see that the gauge faceplates have a green coating on the back, but this doesn't seem to affect the colouration (much).
Once completed the gauges look alot whiter, but if you are picky like me, you will notice they aren't as white as the picture in the first post, they look a fair bit orange. This is probably due to the fact the standard bulbs are incandescent.
In this other post, a guy has replaced his R33 dash bulbs with compatible aftermarket parker bulbs, I will investigate tomorrow whether this is compatible with cefiro and if it makes decent results.
http://www.skylinesaustralia.com/forums/in...;hl=LED+cluster
Edited by daisu
https://www.sau.com.au/forums/topic/153344-i-want-i-want/#findComment-2856476
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
