attempted the white dial mod to dash cluster last nite
took 2 smokes straight and i had it done with all the green caps removed and reinstalled (did it in carpark whilst eating hj's as i always carry 3 toolboxes with me full of tools (just incase!))
only problem... they were a yellow tinge... so today took cluster out again and installed phillips ultravission hyperwhite/blue globes...
the cluster is now super bright - i love it... however it now has a green tinge due to the factory dials green coating... so im wondering how to fix this? it has been mentioned to use thinners on the dials to remove the green?
any recommendations?
look closer at the pic i supplied up top there is no green on the cluster... he has removed the factory green on the dials... will thinners work and not f**k shit up? what to use?
  • Replies 73
In the same boat, the cluster looked orange, so I used three T-10 Narva Arctic Blue bulbs and the green coating is now visible. I couldn't find anything T-5 sized though, except for these Monza LED bulbs, but I chose blue and it actually coloured that part of the dash blue. :)
I'm hoping this green coating comes off with a wipe of thinners :(
i hope so too as im super keen to get uber white
also noticed that 1 of the smaller bulbs (not parker size) lights up the speedo from 120-180... so everything on my dash is bright and tinged green apart from that part which is duller and yellow
This is the T-5 bulb that I was talking about, I'm gonna go looking in other auto shops today for something suitable.
led bulbs look shit... just want normal white
went to autobarn - narva do have t5 sized wedge bulbs... i picked one up $2 each... its just normal white not arctic however they said they do do a super white led t5 size - which i will try after i try this normal narva t5 bulb... i really dont wanna use led's as it will mean having to replace all the phillips ultravision ones i just bought and wont be as bright...
just need this green coating gone - whats the go???????
tried to remove the t5 bulb from its holder... it wont come out! not without breaking it... and had a better luke at the new t5 bulb i got which is just basically a new factory normal one so i dont think itll do much
sent the mrs off on a mission tomorrow to find an ultrawhite t5 to match the t10 phillips ones ive put in
she also came up with the idea of tinting the clear plastic cluster cover in 20% tint... so shes doing that tomorrow (hope it doesnt turn out shit!)
ok i finally got home from working on my car, i tried the thinner thing and it works.... but i wouldnt suggest it because it works on the plastic too lol, if your very careful it will look good , i didnt have another part to the cluster to try prepwash on but i think that will do the job perfect. pics in the morning... its sleep time now :D
when f**king around withe my cluster again last nite
i noticed on the back of each dial up to about 80 it is green... then 90 to about 130 or something the lines are white on the back... then green again to 180... wtf?
take pics of the back of the actual dials removed from the cluster? how did it go getting the white and green off? also that shit doesnt feel like it would come off... it sounds like a zipper when you run your fingernail over it
SCORE!
gf did browsing on the auctions this morning. 90-91 cefs had completely different clusters with factory white... i just purchased one now which will be here in 2 weeks... tacho goes up to 9k instead of 8k aswell
no more dicking around with factory cluster
now we wait... if anyonelse wants a late model cluster i can get several more... pm me :action-smiley-069:
ill put pics up tonite of one
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
