Sorry 25t, this is where I got the info from:
'The RB25 twin cam head's variable inlet cam timing can be retained on the RB30 block by teeing off the oil pressure galley on the head and feeding the standard RB25 piston mechanism. This pushes the camshaft through a full 10 degree advance. All oil and coolant galleries mate up perfectly, with the exception of this cam advance unit.'
the above was from http://www.autospeed.com/cms/article.html?&A=0004 .
After reading this, I did some more investigation and was told it was as simple as drilling a hole in the RB30 block to align with the oil galley for the NVCS by more than one source.
Any chance of some photos?
i am becoming very interested in doing this motor build up as a side project after reading both of these threads which are proving to be very informative.
just a suggestion... is there going to be a price guide to go buy to give some of us an idea of the costs associated with the build up.? <-- for the word document that joel seems to be making
I think they want around a grand for the head..
Thats what I was quoted anyhow.
The Bottom end can be had for almost nothing and well the bearings etc can be had from Nissan so i guess a call to nissan may help us out there.
Hi Joel
no ill install the oil pump and squirters of the 25t block,get the crank balanced, looking at the stroke and pistons the comp ration will be higher because of the storke?,ill have to look into this a bit deeper
Steve, no dramas man ,your info is still very usefull
nothing is ever as simple as it COULD be.Ill post some Pics later today. I really want to retain the vvt.
thanks Guys
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
