200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension
  • Replies 148
Posted Images
^ will this be addressed in future kits?
Nope, we haven't found that the brackets are necessary on the Road and Track kit, as most guys doing track work have changed to braided hoses all the way to the calliper. The brackets are there on the Road Kit of course.
:D cheers :D
A few comments;
Coil overs can't fix suspension geometry problems when you lower a 200SX too far. Hence it doesn't matter what brand of coil over over you use, anything below the recomended heights will most certainly result in geometry issues. Stick to a sensible height and you will have a great handling vehicle with good ride comfort.
The "metallic noise" previously mentioned was a loose sub woofer crashing around in the boot and the spare wheel well, which had no spare wheel in it.
The bump stops are 80 mm when untrimmed. The trimming ratio is not 1 to 1, we need to have more bump stop available to absorb the impact the lower the chassis is. Otherwise there is potential for the shock to bottom out. The theory (of 1 to 1) means that 80 mm lowering = zero bump stop, which is pretty silly. Obviously we use a ratio for bump stop trimming that is less than 1 to 1.
I have spoken to Chris at Centreline and he is happy that there are no issues with the kit as supplied.
:D cheers :D
Well, not exactly. My rear is 355mm now and there's still a pretty loud metallic noise when going over hard/high bumps.
Then for the fronts, which is 355mm at the moment, occasionally, I get a little creaking when steering is under stress. Or when going over undulated road surfaces.
Other than that, at the ride height, it's fantastic! :D
Edited by eron
Other than that, at the ride height, it's fantastic! :sick:
Have you taken it back to Chris to check? Last time he spoke to me, he said it was OK.
:dry: cheers :sick:
+1 to Gary aka Sydneykid he has been very helpful throughout the whole process was a slightly longer wait then expected but deffinately worth it car feels amazing. Haven't had a good chance to try it out at its limit but definitely very happy with this product.
Thanks for all your understanding and help Gary!
-Peak
it's already done.
read my review if you want.
Gary if you believe i'm too critical please ask me to revise it. I honestly appreciated your work.
http://www.nissansilvia.com/forums/index.p...60#entry3427886
Sorry for the delay in responding, especially to PM's. The video card in my home PC died and it took me 4 days to find out what it was and fix it. So I am about 110 PM's behind at the moment and trying hard to catch up. Add that to the workload at Superior Suspension (12 to 14 hours a day, 6 days a week) and it will take me a few days to answer everyone.
Hang in there, if you have transferred money, it's safe, I am not going to run off to Brazil with it. You won't miiss out, the Group Buy isn't going to end soon as I have spent some time with Bilstein securing the shock supply for a couple of months at least.
Advanced warning, I am off to the US for 5 weeks from 1st October to 5th November. Checking out some east coast action, Detroit, Chicago, Daytona and the SEMA show in Vegas. So when I don't respond to PM's or emails in that period, I am sure you will understand why.
>_< cheers :D
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
