G'day guru's,
Would really appreciate some help with this!
2 weeks ago I had my R33 GTST Bilstein and Whiteline GB parts installed (basically everything listed) at the recommended place listed on the Group Buy page for my area. Driving around it seemed fine, felt nice etc - until a couple of days ago.
I noticed weird sounds coming from around the front left wheel area while driving. It sounded like a slight grinding noise, and also some squeaks and 'bangs'. I thought it might be because we have had some really hot days all in a row lately - might be the bushes squeaking or something.
Today I decided to see if I could see anything weird in the front left suspension area, and this is what I saw:
Is this dangerous?
Should this have happened with just normal driving on the streets after 2 weeks?
What could have caused this?
Is this going to throw out my settings?
Sorry for the wall of questions :cheers:
I can post up the suspension tuning settings if that is any help too.
Much appreciated guys!
Thanks,
Adam
G'day guru's,
Is this dangerous?
Thanks,
Adam
who installed it for you?
either didnt do the nut up or didnt put the nut on at all.
bolt comes out, you crash and burn...aarrrgggghhhhh...
take this pic to whoever installed the suspension and cut sick at them..
Not happy Jan, reminds me when I had some work done on my car. 1 week later felt like I had a flat tyre, turns out they stripped the studs on my left rear. Damn wheel nearly fell off at 80kph. As the other guy said, take it back and show them. I'd hit them for a free wheel alignment to.
Edited by zed-031
Lucky man. Could have ended up badly. I remember when i had some knocking in my car from the wheel area. We jacked up the car and turned out that who ever last took the wheel off didn't do it up tight and i could just undo all the wheel nuts by finger. The whole thing was just slapping around. Fagged the rim too by being loose. I like to alway check the work done to my car after someone has been playing with it.
DON'T drive it, call the worhshop & let them know, i they're half decent the'll pay for the tow to them to fix it.
What he said.Dont drive a death trap.
I have installed those bushes myself once b4.If the retaining nut,that locks the bolt in place,is tight,then that shouldnt have happened.My guess is that they put the bolt in there but diddnt tighten the retaining nut,with lock washer,up enuf therefore it has just worked it's way loose.
Or maybee they forgot to put the lock washer on at all.Who knows.
Death trap.
Very,very dangerous stuff.
:P:D:D thats just not right.
P.S: Send them the pic as proof of bodgey!
As the guys have said, don't drive it. If they are not there today, then get them on the phone first thing Monday and explain the situation. PM me if you need any further help.
The usual process is to install the bushes but not tighten the nuts fully until after the wheel alignment. My guess (and it's only a guess) is that they have not done the final tighten after the wheel alignment.
:P Cheers :D
Thanks for the help guys :)
Took it back to the place that installed it and got it fixed up. Is it a possibility that there could be permanent damage? Looks like there was a critical lack of attention to detail...
Just glad I didn't crash and burn :P
  • 2 months later...
Out of interest can you name the company? we all know mistakes are made but it would be good to know
If this is somehow breaking forum rules please delete, but the place that installed it this amazing way was the recommended installer for Canberra listed in the group buy thread.
PM if you want me to name names...
im sure to look for that problem now to see if anything is wrong i also herd u have to look out for mechanics who rip ur after market stuff from ur car if u dont know the guy
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
