New guy...
Guest Skyline Fan 01
  • Replies 43
You can get newer 96/97 Series 2 Skylines for under $20k. Like this one is a auto but its in NSW: Skyline 96 Auto
or this one is a manual in bris: Bris Skyline
I didn't realise some 96/97 S2 Skylines are so cheap if you have a look at www.carsales.com.au they are really cheap. Like $18k for a 96 Auto Turbo. Bargain.
https://www.sau.com.au/forums/topic/15359-new-guy/page/2/#findComment-315598
Yeah i jus still don't get the 'sidewall' thing....?
Thanks also for the thoughts on what i should get. I will prob take a family friend round wit me who is a good mechanic, to help out.
Next question: what's the difference between an 'SR' and 'RB' engine? And all of those numbers on the end, or which come with it?
Like i said at the start, i'm kinda new to all this so....
https://www.sau.com.au/forums/topic/15359-new-guy/page/2/#findComment-315898
SR is a 4cyl from silvia and in a few others too, RB engines are in skylines, vl turbo common hore, cefiro etc... the numbers refer to the capacity... then the letters after that mean stuff too :D
so SR20DET = 4cyl, 2.0l, D= dual overhead cams, E = fuel injected (i think) and T = turbo..
so RB25DE = 6 cyl 2.5l non turbo DOHC
https://www.sau.com.au/forums/topic/15359-new-guy/page/2/#findComment-315910
Well done skyline fan for your frank admission. I know jack about cars to i guess but am always willing to learn...I would be keen to hear how you go about getting your car and may pick your brain later as to your strategies and suggestions. Could prove to be a good learning curve mate.
Chaos...all I can say is "what the..." for your saying of the week
https://www.sau.com.au/forums/topic/15359-new-guy/page/2/#findComment-315948
go to www.supercars.net for wallpapers. they've got heaps of cars there, plus skylines.
engine code for GTR is rb26dett, which stands for Race Bred 2.6 litres Double overhead camshafts, Electronic fuel injection Twin Turbo.
not sure what SR stands for, but the ending bit's the same. cept it's not twin turbo.
https://www.sau.com.au/forums/topic/15359-new-guy/page/2/#findComment-316623
um okay....i'm kinda followin most of this......thanks to everyone who has put stuff in so far btw.
Readin' some of the posts this mornin' on this thread and some of the 'jargon' (i'd guess u'd call it) is still kinda confusin me......like camshafts and 'dissy' (????). I guess i can't get u guys to explain 'everything' unless i ask for a specific term.
Thanks to 'speed freak' as well for his comments. Like i said, I'm new to this forum thing, but i'm not gonna come on here and try and kid myself, let alone everyone else, that i'm some 'car guru' or somethin, when i'm definately anything but. I'll definately keep youse updated on how the car hunt is goin, and collect thoughts and stuff along the way
You'll prob see me on here frequently neway, askin about one car part or another so......
Btw, is it so bad to have an auto?
https://www.sau.com.au/forums/topic/15359-new-guy/page/2/#findComment-316924
