I'm really not sure what you mean.
The RB30 block has a predrilled and tapped hole for the new tensioner location as an RB30 only uses one tensioner and no idler on the drivers side or when looking at the block the left side of the block.
Found a pic of my block as it was being built up.
As you can see the flat surface around the place where the tensioner will go.
Mine was a Series II VL Wagon Exec NA Block.
Are the blocks you have Series 1 blocks? Do they have the oil and water lines already tapped? If not they are series 1 blocks.
Are you going to use stainless steel welsh plugs or brass ones as per pic 1?
EDIT: Also the fuel consumption I am getting is pretty damn good..
Slightly better than what the rb20t was getting. :D
The RB20t was getting around 11L/100km's.
heres the pics. i have 3 blocks like the first pic and the other is a genuine vl turbo block
I have a VL na S2 block and it looks like this.
Now I know that VLT and VL na S2 blocks are the same but if you look under the engine block number it will have a number.
6=na
8=turbo
mines a 6 :D
well its all tapped for turbo gear from the factory so its a bit wierd!
also i have another turbo block that doesnt have the machined surface for the tensioner.
so its 5 blocks in total all of which are tapped from the factory.
2 turbo blocks wearing an 8 under the engine number.only 1 has the machined surface!
3 na blocks all of which have no machined surface
dnb My block is the same as yours and it has all the oil and water lines tapped aswell. I have already had it Torqueplate bored, honed and o'ringed so I was thinking of making a washer the right shape and fill around it with devcon (steel putty) and file it back level with the other surfaces. I have bought a second tensioner instead of the idler. I also have to make an adopter plate to fit a 4wd sump as it will be going into a GTS4.
what about the na blocks that ARE tapped but have no machined surface?.
you deleted your post alf! now this looks silly
sorry, getting confused here.
Ok, i've had this convo about rb30 na blocks before with several knowledgable ppl.
Everyone says the s1 rb30 block doesnt have tapped holes for oil and doesn't have the machined surface.. but the same ppl have seen a few s1 blocks with tapped holes.
haha yeah ive had that block done aswell;( its cool though as im selling my old sohc set up to a guy who will buy this block off me as its ready to go. i was gonna do the devcon trick aswell but since i have the option to unload it and i have another block sitting there i will just get the other one machined up.
i think this had better be mentioned in the rb2530 conversion guide!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
