I wont bother going in to the XR specs as we are comparing apples and apples. :D
Specs from here!
---- EL & AU Standard Ford 4ltr
157kW @ 4900 rpm.
357Nm @ 3000 rpm.
---- EL Standard Ford V8 5ltr.
EL - 165kw @ 4500 rpm.
EL - 388Nm @ 3000 rpm.
---- AU Standard Ford V8 5ltr.
175kw @ 4600rpm
395Nm @ 3000rpm
VS Commodore Specs - From Here
---- Standard V6
147 kW @ 5200 RPM
304 Nm @ 3600 RPM
---- Standard V8 5ltr
165 kW @ 4400 RPM - 168kw for Series II -- wow
385 Nm @ 3600 RPM
Sorry to get a bit off topic peoples.. :(
Oh and if you ask why a VS will blow away a EL.. Slap a Manual in the El and a Manual in the VS then watch the EL fly..
The Auto g/boxes in the Falcoons are geared extremly bad.. 80km's in first isn't to good.
If you ask why a VS Auto will blow away a EL Auto.. The Ford's gearing is a lot longer than the Commodores.
Slap a Manual in the EL and you will be suprised how it actually kicks the VS Manual's arse :) If you ever come up against a Manual EL you will notice how quick they are off the line without stalling it up.. A VS V8 has no chance against it and has to reel it in very very slowly.
Hi Guys, you are looking at the horsepower figures and thinking 157 kw for a 4 litre 6 and comparing it to a 160 kw from an RB20DET 2 litre 6. But, take a look at the torque figures, 357 Nm vesus 263 Nm. That's 36% more torque (the V8 is 50%), that's good for turning the auto, stop start traffic, lugging the family, pulling the boat, towing the Skyline race car etc.
The average person who buys one of those (even though they probably don't even know it) is using the low rpm torque way more than the higher rpm horsepower. We, on the other hand like to use the horsepower.
As they say "horses for courses".
Just a quick note, Ford Turbo XR6 BA injectors= Bosh motorsport 560CC injectors. (One of my friends got them flow tested)
And at 87 bucks a injector from ford! it looks like the perfect injector if your running a custom fuel rail.
these injectors should have enough flow for 500-600HP =)
Not sure on imperdiance, i will check with Mr.multimeter when i get home!
I am now at the point were i will be looking for a computer. What type of computer are other people running with this conversion?
I have a couple of questions so bear with me!
MAP sensors? Were do they sit? AFM Vs MAP sensors? pros cons?
I have been looking around a little bit, heard some good stuff about the APEXI-FC, but it because of the AFM its not much good over 300RWKW.... =(
Anyone heard over the Apexi FC pros?? And what other computers use a MAP sensor?
Lots of questions, sorry its all over the place! =P
Cheers,
Trev
any details about the computer Sik32?
I want o get a little bit deeper than that! =)
e.g. How does it measure Air? AFM? MAP both??
what are you running AFM or MAP sensor? were does the MAP sensor mount? whats more accurate?
Microtech sounds ok for the price, but what can it do? is it a complete change over (plugn play computer)? data loging? specs?
Sorry about the questions i just need to know! =)
Cheers,
Trev
Thats fine so the micro tech uses a MAP sensor. NOw were is that located on the RB25? If its not there, (which i dont think it is because it uses a AFM) were do you install one?
Thanks for this dude!
I take it your going to be running the LT12?
if its the same litte black box that i think it is, thats for the electronic boost sensor for the factory gauge. (black box on a peg, with a black hose going into the plenum?)
Anyways in the spec that you posted it says the LT8 only has:
Inj Drivers 4
ign outputs 4
Dont we need 6 ? like the L12?? or are they additional ign & inj?
yer thats the one!!!
Im not expert but it's something to do with the LT8 runs sequential fire, which can still be used on skylines
But the LT12 has 6 which is direct fire ignition and injection. which would give better spark.
Im not worried about the spark, as i will be running 6 external bosch coils when i finish the conversion
Power FC will handle alot more than 300rwkw - in japan they use them on big hp applications. Downside is that you cannot remove the AFM, but AFM is good for street.
Wolf 3D will allow MAP or AFM, Autronic runs MAP, Microtec runs MAP, list goes on.
Have only heard good things about the new Wolf 3D V4.5#, but it will depend on what your tuner is comfy with. Autronic are very good too. One thing you will have with a wolf or autronic is that you can run injectors of either high or low impedance.
Do the ford injectors fit the stock runners? If they are high impedance they would be a good upgrade for RB20DET too.
Hi JNR24, firstly let's dispel a few myths. Here is the chart of AFM meters I use when working out which one/pair to use with a Power FC to achieve the horsepower target.
1 X RB20/25 AFM = 370 bhp = 220 rwkw
1 X Z32 AFM = 420 bhp = 260 rwkw
2 X RB26 AFM's = 475 bhp = 300 rwkw
2 X Z32 AFM's = 700 bhp = 470 rwkw
1 X Q45 AFM = 480 bhp = 300 rwkw
2 X Q45 AFM's = 850 bhp = 550 rwkw
With the Power FC you select the afm from the menu, simple.
A MAP sensor, as it say measures Manifold Absolute Pressure, so you can take the pressure hose from anywhere between the throttle butterfly and the inlet valves. Most people "T" off the boost sensor hose. Some ECU's have the MAP sensor itself built into the ECU box, so you just run the pressure hose to the ECU.
Others have a separate MAP sensor, with a short harness to the ECU, that you stick anywhere convenient.
AFM's, because they very accurately measure the actual air flowing into the engine, are quite simply the best method for determining how much air your engine is using and therefore how much fuel to add.
A MAP sensor simulates measuring airflow by measuring the pressure. It's pretty good, but simply can not be as accurate as an AFM. MAP's also have problems with multiple throttle butterflies (as in GTR's) as you have to take pressure readings from each cylinder. With large overlap camshafts this becomes a real problem at idle and low rpm.
AFM's are not without their own issues on very high performance engines. They measure airflow, it doesn't matter whether the flow is into the engine or out of it,. The AFM will measure it and the ECU will add the fuel. So if you have a big turbo, you can get airflow reversion when you close the throttle sharply and the AFM will measure the air as it goes in and then measure it again when it bounces back out of the turbo. Twice as much fuel as necessary gets added and the engine stalls. You can buy averaging boxes (HKS is one) that eliminate this problem, so that the engine returns to and maintains a stable idle after a rapid throttle closing.
So getting back to your original question, there is no doubt in my mind that for a road car there is nothing better than an AFM sensor driven ECU and that means Power FC. For $1300 you simply take it out of the box, plug it in and the car starts and runs nicely all within 10 minutes. Normal dyno fine tuning, as for any other ECU, would be necessary, before you rip into it.
If you are seriously looking for more than 500 bhp then you are going to have to spend around $20K on the engine and the necessary support systems for that amount of power. In that case I would recommend the Motec/Autronic level of ECU.
There are arguments for the Link, Microtec, EMS etc level of ECU. But as the price of Power FC's continues to come down and the availabilty of laptop tuning and data logging (via Datalogit software) this starts to become less relevant. Plus they are becoming even more common and workshops now have good experience with tuning them.
That's my 20 cents worth, hope it adds to the thread.
Thanx for your post sydneykid, I am running a single turbo and am looking at power figuers of about 400-450 RWKW...... Anything in that chart over 300RWKW requiers two AFMs.....??
Is there away around this on a single turbo setup?
What computer would you recommend with this power figure in mind??
or just run a split air flow pipe from the turbo into two AFMS, with 2 air filters?? GTR styles????
Hi, JNR24, let me make sure I have this right, you are looking at an 800 bhp, single turbo, manual gearbox, 2 wheel drive application?
If that is the case, then I would personally go for a Motec ECU. You are going to benefit from the functionality of models from the M48 Pro (with Advanced Tuning Options) upwards as follows;
data logging
traction control
launch control
full closed loop control using fast and wide lambda sensing
32 bit processing
individual injector trim
individual cylinder ignition trim
air temperature compensation
engine temperature compensation
exhaust gas temperature compensation
over run boost enhancement (anti lag)
wastegate control
gear position compensation
soft and hard rpm limits
intercooler spray control
For that level you are looking at around $6K installed and wired with a base map for running in the engine. With normal tuning do and charge following that.
Hope that is of some help
I've posted this before in another thread, but here it is again.
It's a chart with the different computers and the main features each has so just click here
i've got a HKS FCONV, no idea what features it has but i've been told they are very good if you can find someone to tune it (which hopefully i have).
Cheers,
Andrew
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
