Cusco Zero-2 race spec suspension. (Note: not for sale, asking for opinions on value)
Hi guys,
As stated, these are NOT for sale, but rather I need *your* opinions on how much is a reasonable price for them. I got these things with the car when I imported, but they're far too hard for the roads I'm on. They're fully height/spring rate adjustable, and the dampers are also 5 point adjustable.
I have no pictures, but they're very clean and hardly used, as I swapped them out for the stock stuff as soon as I realised they were too hard. I will try to get some pictures up tonight, but any advice would be good. Wasn't sure if this is the right forum to post this in, but it's better than nothing. :)
They're on the right.
Suspension is really only worth what someone will pay for it.
A lot of cars come over with very expensive coilovers that are too harsh for crappy Aussie roads.
You've done what I'd like to do, get it back to stock soft springs/shocks.
T.
Well, unfortunately the stock stuff is crap. I'm going to get a Whiteline handling kit and replace all the bushes, to see if that will sort things out a bit... but I'm sure the dampers need to be redone.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
