as topic state i have a hybrid fmic and about to install bleed valve. there is no hose going into the intercooler piping. did a search and ppl say they drilled a nipple into there intercooler piping. dont really want to do this. there must be a way to hook it up. any one done this b4? got any pics?
Theres a vac line coming from the throttle body down and under your intake pipe where your bov sits going to your carbon canistor, put a 3 way thingo (cant remember wtf they're called) and then go to your bleed valve there... or use the search button..
actually you need to make one up, do not put vacume to the wastgate, as the diaphram is not designed to work under vacume, it will get damaged. Best thing to do is to drill and tap the stock cast intake pipe, BEFORE the TB and put a screw in nipple into it. That is how i did mine, works well.
A nipple on the pipe would still have vacum?? woudlnt it?
Um... this doesn't make sense about the vacuume to the wastegate damaging the diaphram... doesn't the wastegate open and close on vacuume/boost pressure, isn't it designed like that from factory? And if you are right why does everyone that i've seen just run it from the vac hose, to the boost controller to the wastegate?
the hose that is supposed to go onto the intercooler piping is t-pieced into a hose that runs to where the intercooler pipe joins to the intake plenum if that makes sence. can i just join the bleed valve to that line. if that doesnt make sence ill get a pic later.
no as soon as boost pressure is released the spring forces the gate shut, there is no vacume on the setup, as the stock boost tap is placed before the TB. Introducing vacume to the diaphram can couse the diaphram to pull away from the shaft mounting plate thing, sorry can't remember the techincal name. If you do use a one way valve, ensure that it is placed before the tee peece bleed valve, otherwise you will get boost goign to the gate, and then it will stay open as it will still be under pressure.
the yellow line is the one that is supposed to be connected to the intercooler piping. if i put the bleed valve between the yellow line and the actuator i still dont see how it wont work because the standard boost control is hooked in there and why would the mechanic hook it up like that if its wrong.
As long as that hose has vacume pressure its the right one. Or am i wrong?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
