FS: The old engine out of my R33.. It's Rb25DET done a touch over 100k has high flow turbo, currently doesn't have a loom but it otherwise complete with ECU, AFM, Coils etc. Has been dynoed and made 160odd rwkw on just 10psi. Healthy engine, always serviced with motul I will also supply a Gates Racing timing belt with it. I do have a HD clutch and some other performance parts that can go with it. Looking for $2000. Ph: 0414 224 905
Edited by nismomiles33
https://www.sau.com.au/forums/topic/155694-rb25det-4-sale/
Not compression tested as it aint running in a car, but was in perfect condition when I pulled it out. The reason the engine was removed is I built a RB26/30 Hybrid for my car.
https://www.sau.com.au/forums/topic/155694-rb25det-4-sale/#findComment-2897743
If only you were in wa i would have snapped this up quick smart
Freight isn't overly bad to W.A... Companies send engines regulary. Could possibly work a deal on price to compensate for the freight.
1000 buks without the turbo
Sorry mate, won't sell it for that. I'm not desperate to sell it, so i'll hang out till I get closer to what it's worth as it's in really good conditon.
https://www.sau.com.au/forums/topic/155694-rb25det-4-sale/#findComment-2900817
you mentioned other performance parts, what exactly?
and i am in wa but quite interested, any chance of a rough idea on freight to here?
oh and i'm gonna need a loom, any ideas on how to get one?
https://www.sau.com.au/forums/topic/155694-rb25det-4-sale/#findComment-2904111
Performance parts have nearly all gone separetly. I only have a GFB BOV pictured and a Pod filter. The loom for the engine is 50% there, it has the loom section for the engine just not the one to the ECU.. I have had a number of PM's from WA buyers, so i'll get a price on shipping, but I would rather someone just pick it up!!
https://www.sau.com.au/forums/topic/155694-rb25det-4-sale/#findComment-2909261
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
