I think I read on sau, its better if you run a new power source if you instal a bosch 040. I have done a search and couldn't find a thread on this topic.
If this is the case, could someone guide me through the process?
thanks
Leigh
Edited by woolls
https://www.sau.com.au/forums/topic/155881-040-fuel-pump/
lol, what sauce are you going to use???? I dont think that that would be healthy, lol...... SOURCE....
It all depends on what power you will be aiming for...
Didn't know I was a school, but thanks for being a good teacher and pointing that out :(
And I am looking at the high side of 200rwkw
https://www.sau.com.au/forums/topic/155881-040-fuel-pump/#findComment-2899055
Apparently its just goot to change the wiring from the loom to the pump cos not enough current flows through the factory ones... so yea just change wiring and make sure its giving full 12v+ to get the full potential from the pump, cos its internal you wont need a differnt power source, just a boost so to speak
https://www.sau.com.au/forums/topic/155881-040-fuel-pump/#findComment-2899119
Is it better to re-do the wiring, yes. Is it necessary, maybe not. I ran a Bosch 044 pump for 3 years without any problems with the factory wiring. This includes a 350km trip up north in the middle of a hot summer, and the pump ran so loud you could hear it over the stereo and air conditioning. It used to get louder the hotter it got for some reason. I was actually waiting for it to crap out and ring the NRMA for a tow and a hotel room, but it never skipped a beat and is still going strong 2 summers later and the wiring has no signs of melting or burning.
However, if your wiring melts or your car explodes it's not my fault! :( This is just my tale, I would have upgraded the wiring if I could have been bothered attaching new wires to the fiddle factory connectors. Also if running the pump externally though a surge tank, I wouldn't re-use the factory wiring.
https://www.sau.com.au/forums/topic/155881-040-fuel-pump/#findComment-2899130
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
