Yes that’s right the famous 24 hour endurance racing motor 34N1 RB26DETT :D
This motor is still in the plastic and has never been installed, not a scratch on it. It took a long time to get this motor from NISMO and yes it is very rare.
I was going to put it into my 33gtr Vspec for circuit use, but I just don’t get the time of work to play with it.
I’m looking for $16500.00 cash but I’m in no rush to sell it !
https://www.sau.com.au/forums/topic/156021-r34-n1-motor-u24-brand-new/
You'd probably want to be a little more specific about exactly which specification of N1 Motor it is and where it came from.
If its complete and brand spanking new then its not bad value.
Jash
  • 3 weeks later...
price drop $15,500ono for more info please give me a call
0415052743
the motor was inported form NISMO Factory through Bell Garage about a year ago.
still in plastic, red in coulur u24 r34N1 rb26dett
The motor is complete and brand spanking new still wraped in plastic
no inlet or exhaust manifolds
no turbos
no crank angle sensor
it has the new front diff, water pump turmostat and housing, oil pump ect and all those other little brackets fitted to the motor
its one flash looking donk with paper tag with numbers ect still attached
i don't get much time to get on line so for more info please call or message me
on 0415052743 cheers scotty
  • 4 weeks later...
Here are some photo's as requested. Rolled plastic off for photo's then covered back up after photo's. Serious buyer's ring 0415 052743 for more info as I have limited access to the WWW.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
