Rossman Posted February 13, 2007 Share Posted February 13, 2007 i've read 600 - 650 grams of a/c gas.... can someone please confirm this? where can i find the factory specs? thankyou. - ROss. Link to comment https://www.sau.com.au/forums/topic/156239-how-much-ac-gas/ Share on other sites More sharing options...
BAMR33 Posted February 13, 2007 Share Posted February 13, 2007 Can't buy A/C gas in Aus any longer unless you have a licience. Link to comment https://www.sau.com.au/forums/topic/156239-how-much-ac-gas/#findComment-2903623 Share on other sites More sharing options...
crofte Posted February 16, 2007 Share Posted February 16, 2007 I would leak test the system first mate. Its illegal in this country to simply re gas refrigeration equipment. If it lost its charge there must be a leak. Get the job done properly and make sure they leak test the system. The figure you mentioned about charge weight sounds about right. You should be looking at a coil TD of around 10 'C across your evaporator coil. Link to comment https://www.sau.com.au/forums/topic/156239-how-much-ac-gas/#findComment-2910884 Share on other sites More sharing options...
