Hey boys n girls im going to be having a look a 95 model skyline which has the series 2 front bar and bonet.
My question is, is there a way to tell a series 1 from a series 2 other than just looking at the bumpers and bonets as in is there a plate or something which would have a different code for a series 1 to a series 2?
cheers
daniel
https://www.sau.com.au/forums/topic/156300-quick-question/
cheers
daniel
Hi,
without having the vin checked, you can usually tell the difference by things such as the interior trim of the seats are different from series 1 to series 2. The panel on the rear boot that says "skyline" is colour coded on the series 2. The rear spoiler is a little higher and squared off on the series 2. And my series 2 has driver and passenger airbags- however im not sure if this was standard or an option.. Hope this helps a little.
Damien
https://www.sau.com.au/forums/topic/156300-quick-question/#findComment-2904401
The series one has no airbags either, the series 1.5 has drivers side airbag and the series 2 has both driver and passenger airbags which ShylineR33 already pointed out. There's a heap more differences between them but if I want to know what series Skyline it is I just go straight for the airbags.
https://www.sau.com.au/forums/topic/156300-quick-question/#findComment-2905269
ok sweet well this guy reckons its got dual air bags, the upgraded ecu and the interior trim is different too but its still a late 95. How would it have all the bits and pieces of the series 2 but still be made in 95. i didnt even know there was a series 1.5. Is that just a series one with series 2 bits ?
so im now fairly confused lol
https://www.sau.com.au/forums/topic/156300-quick-question/#findComment-2905359
I wouldnt its easy to change dashs around and im pretty sure on the site ive seen a series 1 with a series 2 dash. The best way to check is put up the VIN number on the Fast thread and it will reveal all.
Series 1.5 had the series 2 motor series 2 wing Drivers airbag but everything else was series 1, Hence the reason why on this site people call them a 1.5.
Cheers
Chris
Edited by alphanumeric
https://www.sau.com.au/forums/topic/156300-quick-question/#findComment-2905583
yeh will do!!! gonna go check it out tomorrow so ill keep you all informed. i hate dodgy people who talk up their cars so much... but yeh tomorrow ill post up the info n some pics maybe
Edited by Bo0oSt
https://www.sau.com.au/forums/topic/156300-quick-question/#findComment-2905592
Isn't the steering wheel for the Series 2 the same as the Type-X steering wheel? They look similar from memory.
Looks the same as most Nissan cars of that age, Late model S14, N15 series II and so on .
https://www.sau.com.au/forums/topic/156300-quick-question/#findComment-2905829
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
