rb26 instalition
i've just finished the conversion ur thinking of , and OMFG there are virtually nil swap over and wait till u get to the mangement section. but there i a very bright light at the end of the tunnel, if u got time a tatience then do it as a the amount of little odds bits that have to be done, it would cost a fortune or they would quickly bodge it.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-320570
I personally wouldn't bother with the RB26DETT Conversion.
I would mod the RB25 up to 300rwkw if that still wasn't enough then by then you need to start toughening up the internals so i would look at slapping a 3ltr bottom end and rebuilding that instead of the rb25.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330304
i've just done the rb26 conversion but was running the autronic smc computer management system prior and found it quite easy.there was a slight mod to be done to the cross member,pulley to be pressed 5mm of the power steering pump to match 26 front pulley'and re-piping intercooling.radiator,throttle cabel,thrust bearing and gearbox all fit no problems.well worth the effort.i hope this helps.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330353
Originally posted by -Joel-
GTS500 how does the Power delivery feel compared to the RB25DET's? i.e off boost, spool speed, response etc?
Drive a GTR and that will probably give a fairly good indication maybe ?
Cheers
Ken
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330368
when the rb25 came out it had 320hp with a small turbo the rb26 has a large turbo that is laggy till 4000rpm and then turns the tyres hard until the rev limiter kicks at 9000.its wild but blew third gear in the box on second test drive at 500hp and 19psi on bp ultimate.its the best thing i've done
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330382
2GU UP, depends on what you want the car for, if you drive it regulary just change the turbo and do teh usual stuff (cooler, exhaust etc) and you will make a easy 220rwkw. If you want more then you have to start decidng if it is worth changine the engine, but the costs will be much larger than doing a few simple mods.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-331029
I was fiddling around with a turbo calc last night and it appeard that what really hinders the RB30DET is the lack of rev's compared to a RB26. The RB26 will rev to 9000rpm where as the max the RB30DET can rev to is 7000rpm - 7500rpm due to harmonics.
Basically the RB26DET was better for all out power in the turbo calc.
However it isn't always about all out power.. No good boost coming in at 3/4 of the rev range for a street car.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-331056
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
