When i was in Japan in 05 I saw a fair few of the Cubes. They look like an awesome car and nothing like what we can get here. I immediately wanted one, but only to be told we cant get them here!
Im excited that they are coming.....but not at 25k!!!
  • Replies 508
Hmmm - I'm writing this in Nagoya, maybe I should try and pick one up while I'm here...
Maybe one of the so called experts, back yarder's or leeches of the import industry who have been around for 10 minutes will get on the band wagon and bring in a shitter..................but as you are aware they are too late.
If you buy one kristian get an early 2003 due to emissions test vehicle.
They won't be $25K, nowhere near it, and DRIFTT-san, I didn't pick one up today (bought too many big $$ cars this week so had to sacrifice my own purchases for the team) but will get in soon once some money is back in the bank in Japan. I'll give you a buzz when I get back.
Edited by Iron Chef
They won't be $25K, nowhere near it, and DRIFTT-san, I didn't pick one up today (bought too many big $ cars this week so had to sacrifice my own purchases for the team) but will get in soon once some money is back in the bank in Japan. I'll give you a buzz when I get back.
Cube on the SEVS (507/00) what about the rest RAWS compliance. i.e. I'm asking
How can I get a Nissan Cube here?
http://rvcs-prodweb.dot.gov.au/sevs/507-00.htm
thats the address for the cube, and have found out that cubes are selling for around 850000Yen FOB, so landed around 14 or so thousand AU, especially with the yen at 101.50 to $1 AUD. will be definately looking into and investing one probably once i see them on the RAWS list.
^^^Sold in Japan, but only as imports from the US, in LHD only. Stupidly expensive...
Sold in Japan, imported from the US? Dude, all of these cars are made in Hino Japan.
Mistype i guess.
Yeah, i missed the post.
Mistype i guess.
The other post wasn't aimed at you, but I'll try again regardless.
Yes, the cars were built in Japan for the US and Canadian markets only, not for local consumption, then a US importer brought them back in to Japan from the US as private imports, in the same way we bring Skylines here.
Japan has no regulations requiring cars having to be RHD, so none of them are converted. Go into a Benz dealership in Japan and you can choose whether you'd like left or right hand drive.
Yes, im well aware o the RHD/LHD situation here. Obviously thats no good for me as im exporting to Oz.
Its daft that the cars get made here, shipped out and then shipped right back in. Simply absurd.
There's a whole industry devoted to it over there - American-spec LHD Japanese cars brought back in to Japan and sold at ridiculous price. Very weird, but understandable when the whole LHD foreign car thing carries much more status.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
