  • Replies 282
ok to make it easier ill say this
I know what you're thinking. "Did he fire six shots or only five?" Well, to tell you the truth, in all this excitement I kind of lost track myself. But being as this is a .44 Magnum, the most powerful handgun in the world, and would blow your head clean off, you've got to ask yourself a question: Do I feel lucky? Well, do ya, punk?
    • Would be good in your car I reckon Johnny. Have seen reports they don't seem to love circuit use and sustained high RPM, but there's so many variables and implementations it's hard to tell fact from fiction.  All that said, is it worth it in this car given how you feel about it? Probs not?
    • I don't know specifically. I *do* know that it is very likely that historically most/all undertray replacements remove the inner liners and people just run without them. When you are hectic (or serious) enough to really want/need a different undertray, you are probably also running wider, taller or different offset wheels and the guard liners are the first thing that rub (or as I said in the other thread, they blow out at high speeds anyway) Of course, that is before the pricing went nuts on R34s, nowdays it is much more likely people want/expect to retain the liners to protect their overall investment
    • Haven’t had a chance to drive it properly yet. It was rwd and pissing down rain when I drove it home and now it’s in the air with the so I can change the oil. Going to do the  gearbox oil while I’m at it as well, may even do the diffs
    • On 12th June, the mechanic could not figure out what the issue was, but the car seems to be flooding with fuel. He was suspecting the tune, thus referred me to a tuner. Although the tuner is not familiar with Nistune, last Monday (30th June), he came over to try and re-map it. Despite the tuner trying to completely stop fuel, it kept sounding like it was pushing fuel. Tuner ended up suspecting either the ECU or Injectors. I do not believe the ECU or Nistune is the issue, as the Nistune software reads and communicates properly. Today, I removed the (new) injectors to see if they are clogged or leaking. Surprisingly enough, after those 3 days of driving, injectors 2 and 3 look very blocked. You can see the difference in the picture. I blew a bit on 3, that is why it doesn't look as clogged as 2. I am still unsure if this is what is causing the no start issue, but I am now feeling that I may have bought the injectors and Nistune without the need to do so, as the problem seems to be coming from somewhere else.
