im selling a used (barely) kkr430 with the dump pipe and v-band clamp. almost brand new condition with bugger all shaft play. driven less than approximately 2000km's.
i currently dont have any pictures, but can be viewed on otomoto's site. http://www.otomoto.com.au/kkrturbo.htm
for those of you who are lazy, here are the specs;
Compressor inlet pipe 69mm, compressor outlet pipe 50mm
48 trim compressor; inducer 53mm, exducer 76.5mm
Turbine wheel outlet 48mm, outer diameter 64.5mm
im looking for $650ono, now $500. $400 picked up this weekend only! -melbourne
i want this thing gone! going to buy a new setup next week people!
call Miguel on 0432315388 :happy:
some low quality pics attached
https://www.sau.com.au/forums/topic/156831-sold/
it actually wasnt bolted on to my car, but a mate of mine made 205rwkw on dr.drift's dyno with standard afm and injectors, someone else on these forums made 210rwkw
https://www.sau.com.au/forums/topic/156831-sold/#findComment-2924341
will this be a direct bolt on to an r33 with all the lines suiting the KKR
wanting to know this too...
also whats the power rating of it aaannndd when does boost come on?
Oh and the 205kw your mate made, was that on a 32 or 33?
:D
Musky
https://www.sau.com.au/forums/topic/156831-sold/#findComment-2964368
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
