the avg exchange lately has been around the 95Yen mark.
edit/ ive emailed them as well, so we shall see what they are charging. If they say the go by the current echange rate, then they will be $491 as stated...
Edited by Bl4cK32
Beat ya to it :)
Hi Patrick,
Thank you for your enquiry. Below is price information as your request.
* SplitFire Super Direct Ignition System (Item Code: SF-DIS-005): 43100Yen (= currently A$459)
* Estimated shipping cost from Japan to your address in Australia: approximately A$50
To order the product, please use one of the order forms on our website.
Regards,
Taki
Perfect Run
Anyways main point is I've imported enough items to know most places won't give you top dollar on the exchange; I guess it's one of the ways they make a profit. But, Im not complaining cos, web based businesses like Perfect Run/ Nengun etc are still the cheapest around :kiss:
Well I might need to consider getting some brand new coilpacks.
As the ones i got from Kansai Borke down under load at high revs on boost.
Im not saying the ones kansai sold me are shit. I believe it might be something else that is causing the coil packs to shit themselves after a while of driving/ thrashing the crap out of my car to see if they are still working or not.
To get Splitfire Coilpacks from somewhere in SA they were going to charge me $917 for 6.
How about No Scotty. I cant fork out that sort of money for coil packs.
I might look into this Perfect Run shop and maybe get the ppl paying for my repairs to concider getting me these
well the trial period with my coil packs ended... back to missfiring with 0.75 bar of boost. now i need to contact slides and get some of my own. if anyone wants to borrow 6 split fires i might be able to arrage for you to test some out but im saying this without asking him (my mate)... see how we go. Im wrapping electrical earth tape around the coilpaks tonight so see if that will work. otherwise next week i should recieve splitfires from slides if i order them now.
Edited by Pauly33GTS-t
Hey Paul.
Can you send my a PM with picks of what your wrapping your tape around. i will consider this aswell after i have seen a pic of what you have done.
By the way. My missing problem is gone.
18 Coil packs sent away to be tested. 16 came back. 2 completely roasted due to overheating problem after fridays accident 2 weeks ago.
Dead coilpacks where both on the 2 rails i had sent away. 1 on each rail. If that makes sence.
I better make a cruise before I sell my car.
DAMMIT...............
There is a big DIY on this in the DIY section of SAU, it shows where and what the cracks appear as and how to tape them. I'm going to try using earthing tape as it is more heat resistant that normal electrical tape. otherwise im going to crank out hi temp silicon goop and slap that on the sides of the coilpaks.
I'll take pics once I'm done for ya. k. I'll also take pics of what gapping my spark plugs will be set to aswell.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
